i found a '94 400L fairly cheap and was wanting to put the drivetrain off of it on my '99 sport 400 to make a scrambler. anybody tried doing something like this?
the parts are very similar. you could probably make it work with minimal work. are you planning on using the whole drivetrain including gearcases and axles and everything or which parts specifically were you planning on using from which machine? if i understand correctly you want to use the parts from the 94 sportsman to the 99 sport?
I was wanting to use basically all the front end: struts,hubs ,gearcase and axles and trans. off the 400l to put on the sport frame.
113.2K members
