02-22-2011, 06:25 PM
Member #12300
2002 scrambler 90cc not running help!!!!
i got a 2002 scrambler 90cc starter is out so i have to kick start
i have spark nice bright blue spark new plug
i have fuel smelled old so i drained tank cleaned carb
i did a compression check kicked it 4 times got 114 115 116 somewhere in there so id say thats good?
i have sprayed starting fluid in the intake still wont fire
have sprayed starting fluid in the spark plug hole still wont fire
i have even checked the reeds from what i can tell they are fine
stator is new and works great
any ideas im about ready to go crazy
i have a 90cc sportsman and kids love that no problems ever have 5 cough suzuki lt 50s cough no problems with them
this scramblers going to be the death of me lol
02-22-2011, 09:33 PM
02-23-2011, 05:24 AM
Member #11907
I have a Scrammy 90 as well. I *think* you have to have the rear brake lever in the locked position for it to start...it is connected to a switch. I'm not in front of the quad right now, but I can go look later if you need me to.
02-23-2011, 10:27 AM
Member #12300
yes the rear brake lever is locked depressed when trying to kick over
can you adjust the ignition timing? if so how??
i got air stucking throught the carb air pushing out the exhaust got spark im just stumped
02-23-2011, 10:39 AM
Member #11907
Is the wrist strap lanyard firmly plugged in? I doubt the timing would be off. Is the ETC switch in the throttle housing ok?
02-23-2011, 11:09 AM
Member #12300
im sure the lanyard is fine and the etc switch cause i have spark
well i checked again for spark i have it wheni hold it about 1/4 inch for the head when i touch the head i still have a spark but its not a good one
02-23-2011, 04:01 PM
Member #11907
I would post your question over in the mini forum on ATV Riders.com. Very large group of mini gurus there.
ATV Riders Forum - Mini ATV 90cc Under ATV Sub-Forum
02-23-2011, 05:28 PM
Member #3687
You said it won't fire. Spraying starting fluid will not make it fire. Starting fluid will damage the engine if you use to much. Now you are saying you have fire. Starting fluid replaces fuel in the carb. 3 things need to happen in order for an engine to run they are spark,fuel and compression. Is the battery fully charged? My son has a 2001 Sportsman 90 it has an electric choke if battery is dead the choke don't work. The choke works on it when you squeeze the brake lever. We need to determine if it's firing or not. I think it's not firing from what I gather. If it's not firing look at on/off key switch,tether kill switch, and rocker on/off switch. If any of those switches don't complete a circuit it won't fire. Look at it again real close and let us know what you find. In the meantime I will put my thinking cap on. Glad to help you.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again  )
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
02-23-2011, 05:41 PM
Member #11907
Good suggestion about the electric choke...forgot the stock carb had that. We're running a power jet carb on our big-bore race ported 90 with a manual choke.
Reason: Spelling
02-24-2011, 12:38 PM
Member #12300
ok i have checked rechecked and checked again
all connections and tight
battery charged and good
took carb apart cleaned cleaned and cleaned
put back together
i do have manual choke switched over yr ago
i checked spark and when compared to my 04 polaris sportsman 90cc it isnt as bright....
checked compression i have 115
i left the sparkplug out had my boy kick start it put my hand where the spark plug goes didnt get much gas on my hand but had some how much should i expect?
so i put plug back in kicked it a couple times nothing took plug out sprayed alittle starting fluid in it put plug in kicked a couple times nothing
i think my spark is the cause of it all weak when compared the sportsman 90cc
2001 polaris scrambler 90 wont start, 2001 scrambler 90 problem, 2002 90 atv artic won,t start help no fire, 2002 90 scrambler won't run without choke, 2002 polaris 90 scrambler wiring diagram, 2002 polaris scrambler 90, 2002 polaris sportsman 90 wiring schematic, how to check stater on polaris scrambler 90 wont start, polaris 90 atv 2002 starter not working, polaris 90 have reeds?, polaris 90 sportsman motor not firing at sparkplug, polaris 90cc won't start, polaris scrambler 90, polaris scrambler 90 no spark, polaris scrambler 90 wiring diagram, polaris scrambler wont start no spark, reed 90 scrambler, value of a 90cc polaris atv scrambler, where is the choke at on a polaris scrambler 90, wiring diagrams for 2002 poloris 50cc
