03-23-2011, 01:06 PM
Member #6485
can you rebuild a clutch without taking it off
i have a 2001 polaris scrambler 500 and i need to rebuild the clutch and i was wondering can you rebuild a clutch without taking off the clutch
03-23-2011, 01:39 PM
Member #11907
Which clutch (drive or driven)? You can change the springs and weights of the drive clutch w/o removing. If you want to change the buttons and/or spring in the driven clutch, you must remove it.
03-23-2011, 02:03 PM
Member #6485
the primary clutch and i need to do a full rebuild like all the bushings and weights
03-23-2011, 05:16 PM
Member #11907
You'll need a pulled then.
02 polaris scrambler removing clutch, can u rebuild a drive clutch for a polaris, can you rebuild a clutch, do you put oil in the clutches for polaris scrambler 500, how do you remove the drive clutch on a polaris 500 scrambler, how does secondary primary drive work on a polaris scrambler, how to fix a polaris scrambler clutch, how to rebuild a polaris atv clutch, how to rebuild polaris atv clutch, how to rebuild the clutch on polaris, polaris atv clutch rebuilding, polaris clutch rebuild instructions, polaris scrambler 400 clutch rebuild, polaris scrambler clutch rebuild, rebuild clutch in polaris atv, rebuild polaris atv clutch, rebuild polaris atv drive clutch, rebuilding polaris atv clutch, rebuilding polaris scrambler secondary clutch, rebuilding polaris sportsman clutch
