Old 03-24-2011, 12:10 PM
jah195's Avatar
Member #13270
50cc scrambler
working on my sons 50cc scambler. Finally got it to run and the only way i can get it to stay running is to remove the air cleaner and hold my hand over the carb opening. Its like it is starving for gas. if i take my hand off it will idle for a few seconds and then start to bogg down, put your hand over the opening and it will catch back up. I dont completely cap off the incoming air but alot of it, you can still here it sucking. Any ideas? Whats the proper way to adjust these carbs?
Old 03-24-2011, 05:05 PM
dwhst9's Avatar
Member #11907
Send a message via AIM to dwhst9 Send a message via Yahoo to dwhst9
Remove and clean the pilot jet (might as well clean the entire carb while you are at it).
Old 03-25-2011, 05:23 AM
welcome to the board
Old 03-25-2011, 09:12 AM
jah195's Avatar
Member #13270
I have cleaned the entire carb. It runs somewhat better. Now it will fire up and idle and after a while start to bogg down. it will start right back up. I have found that if you hold the throttle about half open it will start and run good as long as you drive it around at half throttle or above. If you stop and let it idle or slow down to make a slow turn it boggs down when you give it throttle. Any suggestions?
Also this thing smokes alot more than most 2strokes that i have seen, can you adjust the oil injector? Could that be causing it to bogg after it has idled?
Old 03-25-2011, 11:23 AM
dwhst9's Avatar
Member #11907
Have you done a compression test?
Old 03-26-2011, 07:00 AM
jah195's Avatar
Member #13270
no i have not. what should the reading be?
Old 03-26-2011, 09:51 AM
dwhst9's Avatar
Member #11907
Stock should be around 120 psi.
2002 polaris scrambler 50
2002 polaris scrambler 50 carb settings
2002 polaris scrambler 50cc
50cc scrambler
carburetor settings for 2002 polaris scrambler 50
how much a polaris scrambler 50cc worth used
how much is 2002 scrambler 50 worth
how to remove a polaris 50 carborator
polaris 50 carb adjustment
polaris 50 carb settings
polaris 50 how to clean carb
polaris 50cc quad scrambler
polaris 50cc scrambler
polaris 50cc scrambler sale
polaris predator 50 oil injector adjustment
polaris scrambler 50 carb adjustment
polaris scrambler 50 carburetor
polaris scrambler 50 troubleshooting
polaris scrambler runs when i hold hand over carb
Polaris 50cc predator (2004) loss of power. rom58 ATV Repair and Maintenance 10 01-22-2011 02:53 PM
does anyone make a 50cc quad with reverse? sadworld ATV General Discussion 4 07-06-2010 02:18 AM
50cc chinese atv offroadohio ATVs For Sale 3 04-05-2010 04:41 PM
2002 scrambler 50cc throttle problems Arranb Polaris Scrambler 4 07-20-2009 08:55 AM
