Old 03-29-2011, 05:57 AM
bluemonkey's Avatar
Member #4906
same year different part numbers??
I broke the outer cv joint on my 99 scrambler. there is listed 2 different models for that same year. how can I tell which one I need?
Old 04-03-2011, 08:58 AM
dgsmooth's Avatar
Member #13603
go to bikebandit or cyclepartwarehouse and look into you year of scrambler - you'll see there is a 'ca' designation and a 'cb' designation, there are differences in more than just the cv joints. the easiest way to tell is to look at the shift lever mount. if you go to the section for the shift lever mount, you can see if you machine matches the ca or cb picture. look up under the right front fender and you can see the linkage mount. the ca one has wires coming out of it and the cb doesn't, but look at the pictures yourself and you'll see what i mean. mine is a cb, and i'm having trouble finding cv joints. the previous owner ordered two but they came wrong - likely for a ca 99 scrambler and mine is a cb. anyways i have two brand-new ca ones if thats what yours turns out to be.....
Old 04-03-2011, 12:32 PM
bluemonkey's Avatar
Member #4906
awesome. I'll look at it. my brother broke the outser cv joint.. there are 2different ones on eBay.
Old 04-03-2011, 03:01 PM
I think CV's are the only part that does this, but when you look at the CV description, it should list the brand or name of CV joint. If you look at yours, somewere on there it should also list a brand or name, and you just match it up that way.
are model numbers and part numbers the same
polaris ca or cb?
polaris model number difference
polaris model search
polaris parts ca and cb designation
what does polaris decal ca/cb mean?
Polaris Part Numbers to add Rear Work Lights to 2009-2011 XP's SouthernGypsy Polaris XP 10 04-12-2012 09:23 PM
Part Numbers for 95 Sportsman 400 LA Confederate ATV Repair and Maintenance 4 02-01-2011 06:19 PM
Part numbers cwlongshot ATV Repair and Maintenance 4 10-29-2010 12:26 PM
Model Numbers? 46moo Polaris Sportsman 6 09-10-2010 09:05 PM
need aftermaket numbers clutchman ATV Repair and Maintenance 4 05-16-2009 10:21 AM
