Old 04-05-2011, 11:14 AM
smokinshoes's Avatar
Member #13665
400 rings
When installing new rings on a 99 400 scrambler does it matter where or which way the ring gaps are facing?
Old 04-05-2011, 03:01 PM
Old 04-05-2011, 04:30 PM
4getful2's Avatar
Member #1234
When i bebuilt mine, they gave me a wiseco piston and it had locator pins in the ring grooves , end gaps go there
Old 04-06-2011, 11:46 AM
Member #13665
thanks will check them out
how to install piston rings
installing a piston in 400 scrambler
installing piston ring point
installing piston rings polaris 400
piston ring replacement polaris 400
polaris 400 does it matter where the rings go
polaris 400 piston and rings
polaris 400 piston ring gap
polaris 400 piston rings
polaris 400 rings
polaris 400 sport ring end gap
polaris scrambler 400 rings
polaris scrambler piston install
polaris scrambler piston rings
polaris scrambler ring gap
polaris wiseco piston ring gap
ring gap 400 scrambler
ring gap on scrambler 400
what postion does the rings on a polaris 400 go
what should the ring gap be on a polaris scrambler
NEW! Rock Rings in Hit.The.Gas ATV Wheels & Tires 13 04-09-2011 08:32 PM
700 sportsman piston and rings. atvman2010 ATV Repair and Maintenance 0 03-19-2011 03:45 PM
piston and rings chriso ATV Repair and Maintenance 1 01-14-2011 07:44 AM
