Old 04-08-2011, 06:45 PM
M_Quick's Avatar
Member #13816
Front hub seal
Have a 2001 Scrambler 500 4x4. Front CV joint fell apart. I replaced it with 1/2 shaft and now the hub seal is leaking? So I ordered new hub seal and strut seal. Still waiting on strut seal to arive. My question is on the hub seal does the spring side of the seal go towards the fluid? Hard to tell on old one, time I torn it out.
Old 04-08-2011, 08:04 PM
Old 04-09-2011, 10:49 AM
racer37l's Avatar
Member #5629
Normally the spring side will go toward the center of the hub. Did you look at the o-ring that goes on the outer cover of the hub?
Con
Old 04-09-2011, 03:15 PM
M_Quick's Avatar
Member #13816
Thanks, and thats what I thought. I replaced the right hand side, but it was awhile back and I forgot which way it went in. It is not the O-ring seal leaking, but also have new o-rings. I herd the strut seal is a pain. I didn't replace it last time when I did the right side. So now I get to change them both.
Old 05-01-2011, 01:45 PM
M_Quick's Avatar
Member #13816
I replaced the seals. The strut seal wasn't near as bad as I thought it would be. Put it all back together, and tested, no leaks! So took on a nice ride aprox. 40 miles. And get home still no leaks. I have tons of metal shavings in the one hub! And when on jack stand I have play when whiggling tire from top to bottom. I imagine theres a bearing in there gone or going bad. They all looked good to me when I replaced them in hub. Is this part a pressed in bearing somewhere in the hub? And is something else causeing it to wear? Thanks for any info.
All Balls Front Wheel Bearing Kit | Rocky Mountain ATV/MC
Says comes with seals, I think I paid that much or more for just the hub seal.
2001 Polaris Scrambler 500 4x4
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2008 Honda Trx700xx
06 scrambler 500 front strut seals leaking how to change
2001 polaris front hub
2001polaris wheel seal numbers
99 polaris scrambler 500 hub seal leak
front seal for a 4x4 polaris atv
how to change hub seal on polaris sportsim 500
how to install polaris hub wheel seal
hub seal for 2001 polaris 400 sportsman
i changed the cv joint from polaris scrambler and now is leaking
machine pressed seal on front of polaris scrambler
metal filings in hub of polaris 500 atv
metal shavings in atv hub
polaris atv front hub seal
polaris atv front hub seals
polaris atv hub o-ring
polaris front hub seal
polaris sportsman hub strut seal
polaris wheel seal
poplaris sportsman front hub seal size
replacing hub seals on polaris atv
2001 sportsman 500 front inner hub seal bigdaddysride ATV Repair and Maintenance 8 01-16-2011 05:21 AM
98 sportsman 500 front hub seal Buschwacker ATV Repair and Maintenance 0 10-08-2010 06:16 AM
Leaking from front hub seal 99 sportsman 500 RMR ATV Repair and Maintenance 6 09-28-2010 01:56 PM
Seal leaking, front differential HappyCamper ATV Repair and Maintenance 1 04-17-2010 09:26 PM
500 Scrambler front hub seal instructions Firemanf58 ATV Repair and Maintenance 8 04-10-2010 05:33 PM
