04-09-2011, 06:55 PM
Member #5587
Problem with recoil starter
Pulled on recoil starter andit isnt returning like it should. It returns if you play with it but doesnt snap like it used too. Anyone know how to fix this and is there a gasket behind recoil starter cover. When the atv starts it pulls the cord back slowly, Any help will be appreciated.
04-10-2011, 02:36 AM
Member #2620
I had the same problem with my Magnum, I took the pull starter off and found that moisture has gotten into the cover and the coil spring has some rust all over it. I took this apart and cleaned this the best as I could and then I put some dry grease (graphite) on the spring and it improved the function with the rope going back in. At first, it needed help going back in after using this a few times, the rope was returning on its own, still a little slow, but it does go back in.
Good luck, I hope this helps.
95 Magnum 425 4X4
04-11-2011, 08:35 AM
Member #5587
yeah it does did your starter go out and was there a gasket behind the assembly
04-14-2011, 03:25 PM
Member #2620
My starter still works but I'm having a hard time starting with starter, the battery seems like it doesn't have enough amps to crank it over fast enough to start. Starts right up with the rope.
I don't remember if it had a gasket or not, it's been awhile since i've had this apart. If in doubt, you can always put RTV silicon on where it mates up on the engine.
I've just found a bad hot wire on my quad today, this might be my problem with the battery having the amps to crank it over fast enough. Wish me luck!
Good luck to you!!
95 Magnum 425 4X4
500 scrambler recoil starter problem, atv assembling recoil starter spring, do i need a gasket for [polaris recoil cover, how do i change a polairs 500 magnum atv starter drive, how to fix polaris scrambler pull start recoil, how to fix pull start on polaris 500, how to remove pull start on polaris 500, how to rewind recoil spring on trailblazer 250, magnum recoil rope, polaris 500 magnum recoil, polaris magnum recoil starter, polaris recoil starter, polaris recoil starter gasket, polaris recoil starter repair, recoil cover repair for atv, recoil polaris pull start, recoil starter going in and out, remove reoil starter cover on polaris atv, rewind spring on recoil starter polaris 500 scrambler, scrambler recoil spring
