Old 04-11-2011, 02:29 PM
99xjjoe's Avatar
Member #12711
Fill front hub with oil?
I know you use an allen key and unscrew the plug, drain and refill but i bought my used scrambler from a hack i guess.
The front left hub plug is stripped so i tried an ez out bit and snapped it(guess im a hack too)and cant get it out, also someone kindly stripped all the brake bolts also so the whole hub wont come off. So can i tip the bike and remove the hub cap and drain and fill that way?
2002 Scrambler 500 4x4
Old 04-11-2011, 06:17 PM
Dbez1's Avatar
Member #10159
Just a guess, but I'm thinking drilling it out and retapping it might be a better solution. There are some guys on this forum that really know. I'm sure one of them will find this thread. Best wishes!
Old 04-11-2011, 07:21 PM
M_Quick's Avatar
Member #13816
So if you cant get the drain/fill bolt out, how do you know you need fluid? If your just wanting to drain it and add new, I would make sure you could take it apart right. BTW what snaped the ez out or the plug? if ez out get a better one, and retry.
Right now Im redoing the hub and strut seals on my 2001 scrambler 500 4x4. It's all broke down just wating on strut seals and front brakes. Good luck with your hubs. And btw hows your cv's looking?
2001 Polaris Scrambler 500 4x4
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2008 Honda Trx700xx
Old 04-12-2011, 04:52 PM
Hamilton's Avatar
Member #13659
i was told that the fill hole should be at 5 o'clock and to fill up until it comes out
Old 04-12-2011, 04:53 PM
Hamilton's Avatar
Member #13659
of course thats after you get the plug out
Old 04-12-2011, 06:34 PM
7.62Addict's Avatar
Member #13356
Vise grips work well for stripped bolts, or you can always take a cutoff wheel and cut the heads off. Then you can remove the caliper and so one. Once you replace all the stripped hardware you will be good to go. Having good quality tools is a must. Dont use any of that 12pt stuff.
Old 04-12-2011, 06:43 PM
M_Quick's Avatar
Member #13816
my manual shows 4 or 8 oclock. Im right handed and like a little more so I go about 3:30 or so. 5 oclock would be pretty low, if you ask me thats not much fluid.
2008 Honda Trx700xx
2000 polaris scrambler wheel hub oil
2001 polaris sportsman 500 front hub oil
2001 polaris sportsman 500 hub oil
oil front hubs polaris capacity
polaris atv front hub fluid
polaris atv front hub oil
polaris atv hub fluid
polaris front hub oil
polaris hub oil
polaris scrambler 400 4x4 hub oil
polaris scrambler 400 adding hub oil
polaris scrambler 4x4 hub oil
polaris scrambler front hub oil
polaris scrambler what type fluid do i put in front hubs
polaris sportsman front hub oil
polaris sportsman hub oil
what kind of oil goes in the hubs of a poloris
what oil do you\ put in front wheel hub of 2001 polaris sportmans 400
what type of fluid goes in the hub of a polaris scrambler
witch oil goes where in a scrambler 4x4 500
95 Xplorer 400 hub fill port Thor2911 ATV Repair and Maintenance 0 03-20-2011 03:20 PM
Proper fill level for trans oil - Scrambler? lj-rubi ATV Repair and Maintenance 2 08-24-2010 04:42 AM
Whats the best thing to use to fill oil? bama13 ATV Repair and Maintenance 2 04-17-2010 01:42 PM
Fill Plugs and Drain Plugs bama13 ATV Repair and Maintenance 0 04-14-2010 01:24 PM
