04-14-2011, 04:30 PM
Member #13678
bad top end
I have a 2000 scrambler 500 . It idles fine revs up to half throttle,but above that it starts to backfire through the carb.I cleaned the carb three times cleaned out the tank and the fuel pump. No difference. Does anyone have any ideas about whats wrong.
04-15-2011, 09:48 PM
Member #13862
could be the spark plug or ignition
1998 Polaris Sceambler 400
Mikuni VM38 Carb w/280 Jet
84.5mm Wiseco Piston
K&N Filter
HSP Exhaust
Ported & Polished Intake&Exhaust
ITP Mudlites
23x8-10 Front
22x11-10 Rear
atv backfires trough the carb at half throttle, how to know if top end of atv is bad, how to know your top end is bad in atv, is backfire bad for a scrambler, polaris atv backfiring through carb on throttle up, polaris atv idles but will not rev-cuts off, polaris backfires thru exaust, polaris scrambler 500 backfiring through exhaust, polaris scrambler 500 idles fine pops back, polaris scrambler 500 idles fine will not rev up, polaris scrambler 500 top end, polaris scrambler backfiring thru, revs up fine but when i stomp on it that's when it backfires out carb, scarmbler 500 shuts idles but wont go, scrambler backfire through exhaust, signs of a bad top end, top end backfire polaris scrambler, will atv start with bad top end
