Old 04-22-2011, 06:36 PM
apextrans's Avatar
Member #13457
wheel/tire combo & clutch suggestions please..
I'm not crazy about the steelies & was looking into a solid alum wheel like the ITP or Douglas but it seems there are so many choices in that style wheel. Which is a good trail wheel? Also interested in opinions on a good all terrain tire that is more agressive than the stock 489's. Not looking for a race tire of any type. Good for trails/working/ & a little mud here & there.
Also, I think my belt is slipping pretty good when I pull the trailer around the yard. Is there a better clutch set up than stock for good performance working around the house but also allow me to rip it on the trails/mud?
Any & all recommendations appreciated..
Scott
2004 Scrambler 500 4x4
K&N air filter
Long wish list....all in due time
Old 04-24-2011, 06:28 PM
apextrans's Avatar
Member #13457
geez...anybody?
Scott
K&N air filter
Old 04-25-2011, 01:02 AM
Smoothbassman's Avatar
Member #2920
ITP makes some great wheels. You will not be disappointed with that wheel choice. The only thing to note is that the Polaris offset/backspacing is different than other quads and as a result your wheels/tires will stick out farther from the sides of the quad. ITP refuses to make a wheel with the correct backspacing for Polaris. I would actually pay a premium to have that as an option but its not offered so we are out of luck on that option
For all around riding you have a couple of choices. Maxxis Bighorns or GBC Grim Reapers. Both are great tire choices for a little mud and a lot of everything else.
Finally, your belt should not be slipping pulling a trailer that is under 1,500 lbs. Are you using low range?
  • Polaris 3500 Winch
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 04-25-2011, 06:04 AM
apextrans's Avatar
Member #13457
I don't have low range on the scrambler. High & Reverse. Thanks for the info on the wheels & tires didnt know about the backspacing.
Scott
K&N air filter
Old 04-26-2011, 05:15 AM
Member #2920
Towing will burn up a belt quickly. Just make sure you have enough capacity. Don't overload it.
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
Old 11-03-2011, 05:23 PM
poposcrammy's Avatar
Member #20152
Vision Wheel
go here they got alot of wheels that are the correct backspacing and lug pattern i have the buckshots on my scrambler
2004 scrambler 500 performance clutch
2010 scrambler wheel backspacing
2011 scrambler wheel backspacing
atv tire and rim combo for scambler
atv wheel/tire combo
itp wheels and tires, polaris scrambler
polaris scrambler 500 trail clutch
polaris scrambler 500 wheel backspacing
polaris scrambler 500 wheel kit
polaris scrambler big wheel kit
polaris scrambler tire
polaris scrambler tires
polaris scrambler wheel tire combo
polaris scrambler wheel upgrades
polaris scrambler wheels & tires
polaris scrambler wheels and tires
scrambler atv wheels and tire kit
what a good atv all terrain tire for scrambler
what are good tire combinations for quads
best wheel/tire combo for my 2010 850xp? MNPolaris850XPeps ATV Wheels & Tires 47 01-30-2011 06:53 AM
scrambler 500 parts needed/clutch suggestions 425whpsti Polaris Scrambler 2 12-12-2010 04:13 PM
Tire/wheel question? Big Country ATV Wheels & Tires 4 07-23-2010 06:19 PM
01 Sportsman 400, Tire upgrade suggestions? turbocav22 ATV Wheels & Tires 2 04-07-2010 04:04 PM
850XP too wide after wheel install, suggestions? Thor ATV Wheels & Tires 5 03-11-2010 08:12 PM
