04-26-2011, 02:15 AM
Member #14439
Aftermarket clutch to stock
I just bought an 02 scrambler 500 for the wife after riding a buddies 09. I can't say enough good about these machines from my first impressions.
The 02 I just bought had something in it I am unfamiliar with, an upgraded clutch. This thing stalls pretty high before engaging and taking off. The throttle response is amazing, but it is too agressive for the wife and she does not like the clutch upgrade at all.
I am gonna put the stock set up back in it, but was curious if anyone had the stock set up laying around they would want to sell. If anyone is interested in this one, I will take pictures and try and figure out what brand it is.
04-26-2011, 03:48 AM
Member #13545
Welcome to the forum!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
04-26-2011, 04:14 AM
Member #14439
thank you, been lurking around here for some time now and decided I needed to join
04-26-2011, 04:23 AM
Member #5629
Welcome!
I would just change the primary spring to begin. That should move the engagement rpm back to factory.
After riding with that change, you could change the primary weights. They also control engagement.
Good luck!
Con
04-27-2011, 07:14 AM
Member #5749
welcome to the forum gearhead. i have the stock blue/green primary spring for you.and if it still ain't right i'll sell you the stock weights.it will be abit cheaper.PM me if interested.i'm also in illinois,,,,,,,,,,,,,,,,,,
05-07-2011, 02:48 PM
Member #14439
found an orange spring in it so far
2000 polaris scrambler 500 wont stay in high gear, aftermarket atv clutch kits with stock tires, aftermarket clutch for polaris atv, aftermarket polaris atv clutch, aftermarket polaris atv clutches, aftermarket wheels polaris scrambler 500, epi orange primary spring scrambler 500, polaris 400 revving too high before engaging, polaris 400 sport with orange clutch spring, polaris aftermarket clutches, polaris atv aftermarket clutch, polaris atv aftermarket clutches, polaris atv aftermarket springs, polaris atv reving too high and wont stay running, polaris scrambler 500 clutch spring/blue/green, polaris scrambler aftermarket gear change, scrambler 500 stock clutch spring, what clutch springs to run in a polaris scrambler 500, what is stock scrambler 500 clutch springs, what type stock clutch is in a polaris atv
