Old 04-28-2011, 10:08 AM
WFOWS6_IL's Avatar
Member #14520
light,on/off, override switch issues
I bought this quad not too long ago, but seems to be a short in the handlebar headlight, override, etc. switch.
One day the 4 wheel drive wasn't working. Out of dumb luck, I noticed if I pushed the on/off button hard towards the on position, the 4 wheel drive started working.
The next day it was fine, but then I put it in reverse and the speed limiter would kick in at idle and I could push the override and it would idle fine.
Drove it the other day splashing through water pretty fast and it cut out a couple times.
So I'm thinking I need to replace that whole switch, but after doing some searches looks like the ECM had issues on the older models. Wouldn't think that's the case since the 4 wheel drive would work when I could push hard against the "on" switch, but maybe there are multiple issues.
On another note, something seems to be draining the new battery and assume this is related.
Anyways, before replacing the switch, I wanted to see if there are common ground problems on the switch itself or the wiring? I haven't traced through the wiring yet. Any thoughts are appreciated!
Old 04-28-2011, 12:11 PM
08 polaris 800 switch bypass
bypass overide switch polaris scrambler
can am 400 override switch problems
forum on\off switch on hard drive
how to bypass the override switch on a 1995 polaris scrambler 400
override switch polaris 800
polaris on and off switch
polaris on off light switch
polaris on off light switch diagram
polaris override button not working
polaris override switch issue
polaris scrambler override
polaris scrambler override problems
polaris scrambler reverse light turns on when overide button is pushed in forward
polaris sportsman light switch short
polaris sportsman lighting short
polaris sportsman on/off run switch
short in polaris lights
what is an override switch on a polaris
why does my 2008 polaris scrambler engine cut out after splashing water?
Switch on side of light on 95 xplorer Belldenpugs ATV Repair and Maintenance 2 04-15-2011 11:25 AM
what wires for reverse override switch? 07 sportsman 800 QuickSilver74 Polaris Sportsman 2 01-19-2011 05:38 PM
reverse override switch on 96 sportsman 500 napaman9 Polaris Sportsman 1 12-03-2010 04:18 AM
Mode/reverse override switch? larryhd Polaris XP 3 09-08-2010 04:00 AM
fog light switch location?. cvjoint Polaris Sportsman 13 07-20-2010 06:52 PM
