05-03-2011, 03:19 PM
Member #14703
help! with my first 400 scrambler
i just bought a 400 scrambler 2 stroke. it starts easy but i can ride it for about 40 minutes and then it cuts off. after i wait about 10 minutes it starts right back up.. i put the fan on a toggle switch so it runs all the time, it felt like the bike ran alittle longer but then cuts off again. does anyone have a clue what will cause this? thanks
05-03-2011, 03:33 PM
Member #5749
what you need to do is when it cuts out see if it loses spark, compression or fuel,,,,,,,,,,,,,,,,,,,,,,,,
05-03-2011, 03:38 PM
Member #14703
it almost seems like it gets hot then shuts off. i noticed the fan shroud is missing . when it shuts down the water in the over flow bottle is bubbleling. also i had a banshee once that did the same thing and it was the stator. could that be the problem?
05-03-2011, 05:44 PM
Member #14419
if there is a black bag circuit breaker like on the polaris 4 strokes located near the rear of the quad. then it is probably that. they are sealed but get moisture and dirt in them and then they heat up and kill the quad. they need to be replaced with a fuse i believe it is 40 amp but may be 50 amp.
2007 OUTLAW 525 IRS
2005 TLD PREDATOR HOT SEAT 600
2003 PREDATOR 500
2001 400 TWO STROKE SCRAMBLER
PLUS A DOZEN OTHERS...
05-03-2011, 08:13 PM
Member #14219
If you try starting it right away does the machine back fire or just keep turning over and not firing up?
05-04-2011, 06:00 AM
Member #14703
no it doesnt back fire, it just turns over.
05-04-2011, 06:01 AM
Member #14703
i'll check that out. i seen it was sealed . do i try to open it or just cut it out and replace it?
05-04-2011, 06:04 AM
Member #14703
so once the fuse heats up it wont bow the fuse? the fuse heats up and kills the bike until it cools down then fires back up again?
05-04-2011, 10:41 AM
Member #14703
Ttt..
05-04-2011, 02:21 PM
Member #14219
Thats one thing with this site. I found not many people work on there own machines. I had better luck trouble shooting it my self then suggestions from here. I guess most people just bring there bikes to shops.
03 polaris scrambler fuse, 2003 polaris predator 500 circuit breaker in the little bubble pack, 400 scrambler cdi box, 400 scrambler has no spark, 400 scrambler polaris, 400scrambler no spark, 97 scrambler 400 cuts out high, fuse location on 97 polaris 400 scrambler, if the fan shroud is missing atv will run hot, polaris 400 circuit breaker, polaris 400 runs then cuts out, polaris 400 scrambler fan switch, polaris circuit starter black bag, polaris scrambler 400 no spark, polaris scrambler 400 starts then shuts of, polaris scrambler fan switch, polaris scrambler fuses, polaris sport 400 fuse locatoin, scrambler 500 breaker location, where are the fuses located on my polaris scrambler 400
