Old 05-08-2011, 06:05 PM
Pjljlm's Avatar
Member #14862
4x4 and overide problem 2002 500 scrambler
I have never posted anything before, but I have found a ton of great info in here thank you everyone who contributes.
My 2002 500 has never gone into reverse with out pusing the overide. I found yesterday that when I push the override it only works in 2wd the rear tires.
I also have no 4WD I got stuck yesterday got it home jacked up the rear end and nothing. I see in the manual it asks if the light comes on I am pretty sure it never came on. I know the 4x4 worked last year.
I guess my main question is can these problims be related?
Another question what would happen if I "bypass" the REV limiter (read unplug the black wire)? My thought is no reverse at all.
Final question If I send 12V to the hubs via switch some how will that give me 4wd via the switch.
Old 05-11-2011, 10:24 AM
camppowersports's Avatar
Member #14584
Sounds like you need a new rev limiter. All the problems you are describing can be caused by the limiter. Does your shift indicator work?
Old 05-21-2011, 11:20 AM
Pjljlm's Avatar
Member #14862
Originally Posted by camppowersports View Post
sounds like you need a new rev limiter. All the problems you are describing can be caused by the limiter. Does your shift indicator work?
yep that works
Old 05-21-2011, 03:32 PM
cwlongshot's Avatar
IIRC you don't (Not supposed to) get 4WD in reverse without pressing the yellow button....
Old 08-14-2011, 08:24 AM
drock440's Avatar
Member #17564
Currently I'm having a problem with the plug to the awd switch/throttle not making good contact causing no awd light and awd not working. If I wiggle the plug awd light works and awd works but I noticed yesterday the overide wasn't needed to gain more throttle in reverse. That plug may be related to the override as well. I plan to check in the near future.
02 polaris scrambler 500 problems
2000 polaris scrambler 4wd not working
2000 polaris scrambler 500 not starting
2002 polaris scrambler 4x4 500 ho manual
2002 polaris scrambler 4x4 not operating
2002 polaris scrambler 500 4x4 shifter
2002 polaris scrambler 500 problems
awd stuck on polaris scrambler
does a polaris scrambler override work
how do you shift a 2000 polaris 4x4 scrambler into reverse
polaris atv 2002 500cc
polaris scrambler 4x4 problems
polaris scrambler 500 4x4 reverse by pass switch
polaris scrambler 500 no 4wd light
polaris scrambler override problems
polaris scrambler reverse speedo switch
polaris scrambler reverseoverride
scrambler 400 4x4 problem
why 2000 polaris scrambler is stuck in four wheel drive
2009 scrambler reverse overide eliminator myst3ry Polaris Scrambler 1 04-05-2011 06:05 PM
2002 500 Speedo problem cookies Polaris Sportsman 8 03-29-2011 06:40 PM
reverse overide modification???? bodon Polaris Sportsman 5 03-06-2011 10:27 AM
2002 Scrambler 4wd problem scrambler500HO ATV Repair and Maintenance 4 01-02-2011 06:17 PM
2002 sportsman 500 HO 4x4 problem bigsky Polaris Sportsman 0 04-03-2010 08:44 AM
