Old 05-08-2011, 06:15 PM
Pjljlm's Avatar
Member #14862
500 scramber 4x4 very hard to start
I changed the plug and the spark looks fine but it takes forever to turn over. ( pull start is broke) After it is warmed up it starts right up. Last year my brother in law thought the stator was bad and started to take it apart. I ohm checked the staror and it was fine I suspected battery, but he already had the flywheel off. My question is could that "pick up" spacing be the issue we had that off and ohm checked it. The quad runs good when after it is stared idle and power seem great. No back fires or anyghing like that. (new battery yesterday)
Old 05-08-2011, 08:32 PM
3 Polaris Atvs's Avatar
Member #1102
Try spraying some carb spray in the air cleaner. May have a dirty choke. Common problem on this type of carb.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90
1998 Sportsman 500 4x4
Old 05-25-2011, 06:46 AM
ole red's Avatar
Member #12261
My 08 was doing the same thing and I found intake valve adjustment too tight.
2000 polarirs 500 scrambler hard to start
2000 polaris scrambler 500 pull starter
2000 polaris sportsman 500 hard to start
2002 polaris 500 atv start backfires
find 2000 polaris scrambler 500 replacement metal pull starter
hard pull start polaris
polaris 4x4 250 1984 will not idle hard to start
polaris 500 cranking hard
polaris 500 hard cranking
polaris scrambler 500 backfires wont start
polaris scrambler 500 hard starting
polaris scrambler 500 hard to start
polaris scrambler 500 wont crank over when chokes on
polaris scrambler 500 wont crank when chokes pulled
polaris sportsman 500 hard starting
polaris sportsman hard to pull start
scrambler 500 4x4 2000 starter
what battery do i need for my polaris scrambler 500
why does my polaris scrambler 500 start with pull start and not electerc
Hard start The Raven Polaris Scrambler 6 11-30-2010 04:55 PM
2002 Trailblazer 250 Hard Start paac ATV Repair and Maintenance 11 08-07-2010 11:55 AM
2002 Trailblazer 250 Hard Start paac Polaris Trail Blazer 1 07-28-2010 02:55 PM
Starts hard with electric start Beenthere ATV Repair and Maintenance 3 06-08-2010 02:21 AM
96 trail boss hard to start thornhill_motorsports23 ATV Repair and Maintenance 1 12-03-2009 12:19 PM
