Re-building 400 top end.
So i did a compression check on my 400 again this weekend.
Its at 103 psi. I read they are saposed to be around 125-145 is this correct?
I figured since rebuilding the top end is cheap anyways i would start it next week.
So i wanted to know which piston company you guys suggest and why you suggest them over the others.
The two im thinking about using is
Namura
And
Wiseco
I read about both of them. Both claim to be stronger than stock. Which one should i go with?
