Old 05-15-2011, 05:11 PM
alankulwicki7's Avatar
Member #5592
2000 Scrambler Drive Belt Adjustments?
Hey all
I've got a 2000 Scrambler 500 4X4 that I picked up last fall. It starts and runs great but the other day the drive belt was slipping. It happened when I was driving through a puddle about 8" deep. Once I got out of the puddle, it seemed to go back to normal.
I wasn't sure if water got into the case or what but when I took it apart tonight, it was completely dry. The previous owner had installed a new belt and it looks new.
Since this is my first Scrambler I don't have much experience with it (I have owned 4 Honda XR's before the ATV). It seems like the belt is loose because I can turn it by hand pretty easily. I also noticed that the belt seems to have a fair amount of play between the 2 clutch plates. It's hard to tell in these photos but I bet there's 1/8" of play in there:
Is this normal? If not, what should I do to get rid of the play?
Thanks!
Doug
Old 05-15-2011, 07:03 PM
Old 06-04-2011, 08:06 AM
scrambler1's Avatar
Member #6485
Originally Posted by alankulwicki7 View Post
Hey all
Thanks!
Doug
k i have had the same thing happen to me and i had a brand new belt on it. it was water in the case and right after i went and pulled it off and there was no water either but i think the engine heat dried it out and the clutch slinged the water off of itself
Old 06-04-2011, 08:07 AM
scrambler1's Avatar
Member #6485
Hey all
Thanks!
Doug
and the play in the clutch thats normal too mine has that
Old 06-25-2011, 09:12 AM
Rooster0310's Avatar
Member #16279
Case seal is letting in water. The case warps over years and the seal cant keep out the water. You could replace the seal but the problem could still be there due to the warped case. As for the gap dont remember, I havent had my case off for a year.
2000 poalris scranbler 500 belt
2000 polaris scrambler belt
belt case seal scrambler
belt on 2000 polaris scrambler 500
clutch adjustment polaris 90
drive belt adjustment on polaris scrambler
drive belt for 2000 polaris scrambler
drive belt for a polaris 2000 scranbler 90
honda scrambler how to drive
how to adjust a drive belt on a scrabbler 500
how to adjust drive belt on polaris scrambler
how to adjust polaris belt tension sportsman
polaris 2000 50cc scrambler drive belt diagram
polaris 500 drive belt adjustment
polaris scrambler belt adjustment
polaris scrambler belt tension
polaris scrambler belt to loose
scrambler 500 belt to loose
scrambler drive belt problems
help with drive belt MattRoss257 Polaris Sportsman 4 08-07-2010 01:14 AM
Best drive belt for 850 antz01ta ATV Performance Modifications 10 05-09-2010 09:16 AM
05 Scrambler Drive Belt Tension kevinvinv ATV Repair and Maintenance 0 03-09-2010 07:03 PM
2000 Trail Boss Drive Belt sickofit ATV Repair and Maintenance 0 03-02-2010 11:13 AM
2000 325 Magnum 2wd - drive belt coming apart eichhoma ATV Repair and Maintenance 7 12-22-2009 12:31 PM
