Old 05-17-2011, 05:35 PM
2strokeman's Avatar
Member #15146
need some help!
i have what i think to be a 97 scrambler 400 4x4. my problem is it will run for about 5mins then bog and stall. 6-15 hard pulls later(because the battery is shot) it will fire and then do the same thing. please help me and thanks
Old 05-17-2011, 05:51 PM
3 Polaris Atvs's Avatar
Member #1102
Well you have lots of things to check. How long has it been sitting. How fresh is the gas? What kind of compression do you have. I have a 96 with same problem. It needs a rebuild. Crank bearings are bad and it starts to suck through the seals when it gets warm and shuts down. Just rebuilt one of my trailblazers for same problem.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90
1998 Sportsman 500 4x4
Old 05-17-2011, 05:57 PM
2strokeman's Avatar
Member #15146
no idea how long it sat. new gas. decent compression. a cupel days earlier it ran perfectly. the overheating light has been flickering. but its never hot
Old 05-18-2011, 03:48 PM
2strokeman's Avatar
Member #15146
anyone???????????????????????????????????????
Old 05-18-2011, 04:06 PM
cwlongshot's Avatar
Change out that fuel filter, tank vents and check the spark plug and air filter too.
Then get yourself some Seafoam and foam it baby!!
As few as a couple tanks makes quite a difference to a neglected carburetor!
Old 06-02-2011, 06:25 AM
Malibu Dru's Avatar
Member #7975
Fix
[QUOTE=2strokeman;97019]i have what i think to be a 97 scrambler 400 4x4. my problem is it will run for about 5mins then bog and stall. 6-15 hard pulls later(because the battery is shot) it will fire and then do the same thing. please help me and thanks[/QUOTE
ONe thing is for certain. You don't want to run your machine without a battery. Your cooling fan runs off your battery. if it gets hot and can't cool itself it will shut off and once its cooled down you can start it back up again.
Another thing is your carb. Take it down, clean all your primary holes and be sure to clean the bowl. A brown tinted slush forms and clogs everything. Lastly delete your oil pump and mix your own gas. its more accurate that way and it can save you from burning up your engine
Old 06-02-2011, 06:55 AM
xcheck21's Avatar
Member #8803
CARB???
1995 scrambler 400 stall
pic of oil pump line carb line scrambler 250
polais 500 flickring gas guage
polaris crew getting hot how can i cool it down
polaris flickering gas gauge
polaris+scrambler+400+bogs stalls
scrambler 400 bog
