Old 05-26-2011, 02:43 PM
sr975j's Avatar
Member #13454
2000 scrambler wheel hub question
ok so i have a 400 scrambler and the front wheel bearing went out...i thought. i took it all apart and found out the hub clutch ( #5 in the parts list...or detail A in the top right corner) was also destroyed. it was actually broken. i am replacing the wheel bearing also.
OEM Parts Polaris SCRAMBLER 400 (A00BG38CA) 2000 FRONT WHEEL - A00BG38CA - Cheap Cycle Parts
so my question is, do i need to have that hub clutch in there if i dont use the 4wd? the guy i bought it from broke an axle and decided they were too expensive to fix so he just ran it around in 2wd. the hub clutch is an expensive part and i really dont want to buy a part for my 4wd which i dont even use. so do i need have the hub clutch in the hub in order for me to ride it in 2wd?
Sam
Old 05-26-2011, 04:49 PM
M_Quick's Avatar
Member #13816
Maybe this will help. Im having my share of problems with the front hubs on my 01 500 scrambler 4x4.
1999 POLARIS 400 SCRAMBLER 4X4 LEFT FRONT HUB CLUTCH | eBay
2001 Polaris Scrambler 500 4x4
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2008 Honda Trx700xx
Old 05-27-2011, 02:24 AM
mechanike's Avatar
Member #5749
thats a great price,,,,,,,mine went for $90. i'd jump on it!!!
Old 05-27-2011, 04:46 AM
sr975j's Avatar
Member #13454
thanks for the link but my question is do i have to have the hub clutch installed if im not using the 4wd? the previous owner took out the front axles since he broke one so i only have 2wd.
Sam
Old 05-27-2011, 02:22 PM
M_Quick's Avatar
Member #13816
Sam
Not 100% but I'd say YES! Cause there are bearings inside and out side of the Hilliard clutch system. W/out it the bearings would not stay where the need to be, just my opinon. Check out this maybe it will help?
2008 Honda Trx700xx
Old 05-29-2011, 09:17 AM
sr975j's Avatar
Member #13454
thanks a lot for the video. that really cleared it up for me. does anyone have an opinion on whether i need to have the hub clutch or not?
Sam
Old 06-02-2011, 06:24 AM
sr975j's Avatar
Member #13454
ok one more question about this. in the video, i see 3 bearings being installed but in many parts kits ive found on sites like ebay list the front hub with 4 bearings and the hilliard clutch. so if there are 4 bearings, where does the 4th go? i dont get it
Sam
Old 06-11-2011, 04:13 PM
M_Quick's Avatar
Member #13816
There is a 1st bearing in the inside of the strut. Video just shows him putting outside strut bearing #2 in. And then the hilliard clutch, one more bearing#3. And then he puts on hub and installs 4th bearing. You can get parts break down on line alot of sites, try Cheap Cycle Parts
2008 Honda Trx700xx
Old 06-19-2011, 05:35 AM
dhondo's Avatar
Member #15290
What oil do you put in? anything that can be bought at a local auto parts store?
Old 06-19-2011, 07:32 AM
M_Quick's Avatar
Member #13816
Supposed to used the polaris on demand hub fluid. I have herd and used type F trany fluid.
2008 Honda Trx700xx
2000 polaris 400scrambler how to change front hub oil
2000 polaris atv parts diagram
2000 polaris scrambler 400 4 wheel drive problems
2000 polaris scrambler wheel hub oil
2003 polaris scrambler 500 hub oil
2006 polaris scrambler clutch
buy polaris scrambler wheel hub assembly
do the polaros scrambler & sportsman share parts?
how hard is it to take apart 2000 scrambler 500
how to change an atv wheel hub
polaris hub clutch problems
polaris scrambler clutch,fr hub
polaris scrambler what type fluid do i put in front hubs
polaris sportsman hub changed with polaris scrambler hub
what kind of oil do i put in my wheel bearing on my sportsman?
what kind of oil do you put in the front hub of polaris scrambler
what oil do you\ put in front wheel hub of 2001 polaris sportmans 400
what type of oil do you put in front wheel of polaris scrambler 4x4
scrambler 500 tire/wheel question scrammy500 Polaris Scrambler 16 11-12-2011 06:57 AM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 ATV Repair and Maintenance 5 03-23-2011 11:01 AM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 Polaris Scrambler 2 02-15-2011 04:22 AM
2000 scrambler wheel steel or alum? Can they be straightened? 01somta ATV Wheels & Tires 1 01-04-2011 03:46 PM
2000 scrambler front wheel bearings hugeyota Polaris Scrambler 0 10-17-2010 05:40 AM
