Old 06-05-2011, 12:23 AM
ONEBADDSCRAMBLER's Avatar
Member #15699
05 scrambler wheel base lengths
I have a 05 scrambler 500 4x4 that i recently bought when i got it home i noticed that the rear axle didnt look square with the frame so i measured the wheel base and the right side measures 38.5 and the left side measures 39.5. the machine had been rolled before but none of the plastic was torn so i didnt think that it was wrecked that bad the top frame rail by the battery box is bent to the right and i inspected the whole frame and that was the only thing that i saw bent. I also have a 89 trail boss and an 04 sportsman I measured the sportsman and the wheel base was the same on both sides then i measured the trail boss and it was the same as the scrambler 1 inch longer wheel base on the left side shoul i start looking for a frame or is this normal for this machine also the tires are in good shape with no irregular wear
Old 06-05-2011, 05:17 AM
Old 06-06-2011, 09:17 PM
OutlawJim's Avatar
Member #15669
I think you may be okay....the rear swingarm on the Scrambler (at least the one that I have, 2003) is diagonal rather than straight back, I think this offsets that axle length with the sprocket/rear brake setup. We need someone with a mint Scrambler to take a measurement. I'm at work but I'll take a look when I get home!
'07 Outlaw 525 IRS
HMF Elliptical Exhaust/MoorePower Ceramic Header
K&N Filter/EHS airbox lid/JD Jet Kit
MotoX coated A-Arms/Nerfs/Bumber/Grab Bar
Pingel Kill-Switch/Wrath Anti-Vibe Clamp/Pro-Taper bars
Old 06-10-2011, 02:25 PM
Member #15699
thanks i have been riding it and it seems to drive down the road sraight.
atv wheel base
atv wheelbase measurement
average atv length
average atv wheelbase
how is polaris wheelbase measured
polaris scrambler wheel base
polaris scrambler wheelbase
scrambler 500 wheel base
scrambler wheelbase
what is atv wheel base
what is the wheel base for an atv
what is the wheel base on a atv
wheel base atv
wheel base of a atv
wheel base of atvs
wheel base of scrambler
wheel base on a 2000 polaris scrambler 500
wheelbase on a atv
wheelbase polaris scrambler
scrambler 500 tire/wheel question scrammy500 Polaris Scrambler 16 11-12-2011 06:57 AM
2000 scrambler wheel hub question sr975j Polaris Scrambler 9 06-19-2011 07:32 AM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 ATV Repair and Maintenance 5 03-23-2011 11:01 AM
01 Scrambler 500 4x4 left front wheel engages when in 2 wheel drive pontiac69 Polaris Scrambler 2 02-15-2011 04:22 AM
Looking for rear rack entender for my 2011 Sportsman 500 base model. rickyjr15 ATV Visual & Body Modifications 1 01-22-2011 07:43 AM
