06-11-2011, 06:59 AM
Member #15870
New axle in 02 scrambler grinds when put into gear
Hey guys i just picked up an 02 scrambler 500 4x4 and put a new axle in. got it all together went to put in gear and it doesnt go but it grinds alot
Any ideas??? Thanks
06-11-2011, 07:12 AM
Member #3687
The shift linkage might be out of adjustment
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again  )
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
06-11-2011, 08:41 AM
06-11-2011, 04:46 PM
Member #15870
i thought of that it does that when i have the chain on but it doesn't do it when the chain is off
06-11-2011, 04:49 PM
Member #12568
your engine might be idling a little too fast
06-11-2011, 05:03 PM
Member #15870
i think it is but i turned the idle screw but the idle doesnt go down at all
06-12-2011, 04:18 AM
Member #15824
Sounds like the clutch is engaging at idle. Take the cover off and see if the secondary clutch is turning at idle.
If so, time for a primary clutch rebuild.
06-14-2011, 05:53 PM
Member #15870
The cover with the belt behind it and what should i be looking for??
06-15-2011, 04:58 AM
Member #15824
Yes, take the cover off, and see if the rear clutch is turning while the bike is idleing.
2001 polaris transmission grinds going into gear, 2001 scrambler 500 grinds going into gear, 2008 polaris scrambler 500 rear axle shifted, 99 scrambler rear bearing torque, if polaris scrambler grinds when putting into gear what is wrong, linkage adjustment 99scrambler, polaris 300 grinds when put into gear, polaris 350l 4x4 chain tightening, polaris 425 4x4 grinds in to gear, polaris scramber grinds in gear, polaris scrambler 500 rear axle, polaris scrambler gear grinding, polaris scrambler gearing, polaris scrambler rear axle adjustment 1999, polaris scrambler rear end adjustment, rear axle scrambler 500, scrambler grinds, scrambler grinds when put in fear, scrambler grinds when starting, what grinds on the axle
