Old 06-13-2011, 08:20 AM
tekrsq's Avatar
Member #6432
Hour meter ????
I'm picking up an 05 Scrambler 500 on Thursday, and was wondering is there a way to determine mileage and or hour usage ? Supposedly it has less than 75 hrs, and I've already looked at it. It looks ok (typical mud, scratched fenders, etc), but I'd REALLY like to know if there is a way to definetly determine its usage.
Oh, almost forgot. I'm going to be changing the fluids in it when I get it. Other than the oil, coolant, and diff fluids, are there any other fluids in it? Any special type of antifreeze needed for it ?
Thanks.
08 Sportsman 800 Touring- 2500lb Polaris winch, front & rear brush guards, front rack extender, headlight Mod, Quadovator temp gauge, RAC Engineering reverse/ work lights, Polaris rear storage box
05 Scrambler 500 (wife's bike)- Polaris rear rack, Bear Claw tires
Old 06-13-2011, 10:46 AM
4getful2's Avatar
Member #1234
In terms of low udage, you kinda have to look at the obvious. If it HAS 75 hours, let say that equals out to 750-1000 miles, so tires should be in good shape , not too much rust on the entire exhaust, front-end still tight
1999 polaris sportsman 500 hour meter mph
2011 polaris touring 500 hour meter location
atv hour meter
atv hour meter polaris
changing kph to mph on polaris sportsman\xp
do 2000 polaris have hour meter
does an 05 scrambler have an hour meter
does the polaris scrambler have a hour meter?
how do you read polaris atv hour meter?
how to check hour meter on polaris 850 xp
how to read hour meter on polaris sportsman
how to switch the hour meter to miles on polaris 500 sportsman atv
is there an hour meter on a polaris sportman
polaris 500 read hours
polaris 850xp 2011 hour meter
polaris hour meter
polaris sportsman hour meter
what does hour meter on polaris 850 xp look like
Would you drive an hour to save $300 on a new Quad?? WilliamBos Polaris ATV Polls 31 02-18-2012 12:30 PM
how to change polaris 850 XP 2011 meter from mph to km/h metal Polaris Sportsman 4 05-28-2011 10:27 PM
Still not cranking can't afford to pay shop hour cost please help hallmike ATV Repair and Maintenance 1 05-19-2011 02:17 AM
2010 Sportsman 500 H.O. dies in idle first hour? And several times since... OC2010 Polaris Sportsman 5 10-21-2010 01:37 AM
10 Hour Brake in Service VegasRider Polaris Sportsman 3 06-09-2009 10:01 AM
