Old 07-03-2011, 07:44 AM
QuadCorey's Avatar
Member #12911
Idle problem
First off i have a 2000 scrambler 400 4x4.
My problem is that whenever i am riding on the trails it wants to bog down and stall out, but if i flip the choke on it saves it from stalling. It also like to stall out when shifting from neutral to H or R.
I tried adjusting the idiling screw and that helped a lillte bit but the same problems still occur. I am thinking that a carb rebuild is needed but not sure.
Has anyone else had stalling or bogging out problems if so what caused them?
Old 07-03-2011, 07:51 AM
cwlongshot's Avatar
Welcome Ohio!!
I agree with you, a carb rebuild is your best bet. But you can try a tank or two of SEA FOAM and see if that does the trick. I have used it for years and many times if its just jarnish it will cure the problems.
Old 07-03-2011, 07:58 AM
QuadCorey's Avatar
Member #12911
i ran a gas tank worth of seafoam(4 oz) through it already. The wierd part is that it ran pretty good with the seam foam running through it but as soon as i put a new tank of gas in, same problems came back.
Old 07-03-2011, 08:12 AM
cwlongshot's Avatar
Wink
Originally Posted by QuadCorey View Post
I ran a gas tank worth of sea foam(4 oz) through it already. The weird part is that it ran pretty good with the seam foam running through it but as soon as I put a new tank of gas in, same problems came back.
Well, as I said, your best bet is a rebuild, but I also suggest a tank or two.
Sea Foam is not a cure all, but its damn good stuff. They comes in 16oz cans, try another tank or two, you already have the sea foam. Nothing to hurt...
2000 polaris scrambler 400 idling
2000 polaris scrambler 500 4x4 idle adjustment
2007 polaris scrambler 500 4x4 carb tune idle
94 polaris 400 4x4 choke
how do you change the idle speed on polaris predator 90
how to adjust idle on a 2000 polaris scrambler
how to adjust idle speed for polaris scrambler
how to adjust idol on 2000 polaris scrambler
how to idle a polaris outlaw predator
only idles with choke polaris
polaris outlaw 50 belt adjustment
polaris outlaw 50 belt adjustment -predator -90
polaris outlaw 50 idle problem
polaris outlaw high idle
polaris outlaw idle high
polaris trail boss 700 adjust idle
polaris trail boss revs high when i choke it
scrambler 400 choke spring
scrambler 400 idle screw
where is idle on outlaw 90
06 x2 500 need idle help? bmosesso ATV Repair and Maintenance 2 04-30-2011 05:49 AM
CVT Problem... Belt slap at Idle... 97 Xplorer iif3lixii Polaris Magnum 2 07-23-2010 04:58 PM
How to set idle? ferg_29 Polaris Outlaw 1 06-03-2010 04:44 PM
1994 explorer 400L 4X4 idle problem GREYWOLF1957 ATV Repair and Maintenance 3 11-27-2009 09:32 PM
Cold Start Idle Problem - Suggestions Atv Dad Polaris Scrambler 4 11-08-2009 01:50 PM
