Old 07-04-2011, 05:29 PM
tekrsq's Avatar
Member #6432
Scrambler 500 sputters after getting wet
The wife's 05 Scrambler started to sputter after she went PLOWING through a puddle about 12" deep. Water was flying....it looked she was in a boat !!! Anyway, after that it sputtered and coughed for about 10 minutes. Then it smoothed out and ran like normal. I checked the airbox, and it was dry. I'm pretty sure it was an electrical connection.
Anybody had this happen, or can give me good place to start looking?
08 Sportsman 800 Touring- 2500lb Polaris winch, front & rear brush guards, front rack extender, headlight Mod, Quadovator temp gauge, RAC Engineering reverse/ work lights, Polaris rear storage box
05 Scrambler 500 (wife's bike)- Polaris rear rack, Bear Claw tires
Old 07-04-2011, 05:38 PM
cwlongshot's Avatar
Likely simply water got between the plug wire. Either at the box or at the plug itself. WD40 will displace the water. In either case is likely to happen to ANY vehicle driven like that... The cure is don't drive into water at speed...
Old 07-05-2011, 10:48 AM
Gear_Head's Avatar
Member #14439
I have read where the throttle position sensor is sensitive to moisture.
Old 07-05-2011, 07:46 PM
Bulldogge's Avatar
Member #16536
I bought a Scrambler for my wife also. She impressed me today. We had to climb an old washed out powerline. It was very rocky and steep and about a half mile long. My ass puckered as I climbed the powerline. lol
My point is it is cool when our wives share our hobbies. It's alot easier to get out and ride if we let them tag along. lol
Old 07-07-2011, 12:47 PM
QuadCorey's Avatar
Member #12911
You should be alright if the airbox was dry. When you fly into water it's bound to get into nooks and crevis and cause some kind of problem
03 polaris scrambler 500 4x4 sputters then will turn off
03 polaris sportsman700 have a wet clutch
2006 polaris scrambler 500 problems
2006 polaris scrambler 500 water issues
2006 scrambler sputters when it gets wet
2007 scrambler 500 racks
2007 scrambler 500 sputtering
2007 scrambler rear rack
2011 scrambler 500 rack
atv sputers when wet
atv sputter
atv sputters wet
ok for atv to get wet
polaris scrambler 500 2006 surepower
polaris scrambler 500 starts but sputters under throttle
polaris scrambler having trouble when it gets wet
polaris sportsman 800 sputters in the water
scrambler 500 sputtering after washing
why my polaris 500 sputters when it gets wet
engine sputters at low rpm samueladams205 ATV Repair and Maintenance 12 05-08-2012 11:06 AM
HELP! 700 EFI Spits, Sputters, and Dies AKStew ATV Repair and Maintenance 9 07-04-2011 11:03 PM
XP 850 Sputters or Dies yotesniper66 Polaris XP 10 03-27-2011 06:03 PM
Spits and sputters joeptc ATV Repair and Maintenance 1 03-10-2010 12:35 PM
2006 700 efi spits and sputters joeptc ATV Repair and Maintenance 0 03-09-2010 04:58 PM
