07-11-2011, 05:01 PM
Member #16701
500 sputters at no load
Hi, my wife's scrambler has been sputtering or missing only at a cruise or no load. Seems to be worst at probably 10-15 MPH. I put a new plug in it tonight which didn't seem to help. Old plug looked great too.
I am picking up an inline fuel filter tomorrow along with a new air filter.
What would be my most likely problem. Runs great when you accelerate.
Thanks,
Mohntr - Missouri
07-11-2011, 07:07 PM
07-12-2011, 05:22 AM
Member #3687
You might have some trash in the carb. You might have to remove the carb and clean the jets. Before doing that I would add some Seafoam fuel treatment to the gas. It only takes 1 oz per gallon of gas.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again  )
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
07-13-2011, 09:55 AM
Member #16701
Yes, I was hoping for a simpler solution. I will pick up a carb kit and dig in.
Thanks,
Mohntr
Sent from my Droid using Tapatalk
07-13-2011, 10:22 AM
Member #3687
If I were you buy a can of carb cleaner and clean old parts. Remove jets and run a small wire thru passages. You might not need any parts. It might not be a bad idea to drain tank to make sure you don't have trash and water in it. Always use some sort of fuel stabilizer. Alot of fuel problems are caused by ethanol gas.
1995 425 4x4 Magnum
07-13-2011, 10:39 AM
Member #16701
So you think I can reuse the gaskets?
07-13-2011, 11:31 AM
Member #3687
Yes, after removing the float bowl screws tap the bowl lightly with the handle of the screwdriver. Works like a charm. I have rebuilt over 10 carbs this month and have not bought a gasket yet.
1995 425 4x4 Magnum
07-13-2011, 11:45 AM
Member #16701
07-13-2011, 11:50 AM
Member #3687
You are welcome
1995 425 4x4 Magnum
07-24-2011, 11:31 AM
Member #16701
Just an update, finally pulled the carb, cleaned it up and the bike runs great. No more sputtering.
Thanks.
Sent from my DROIDX using Tapatalk
2011 polaris sportsman 90 engine sputters, 90cc polaris sputters, 99 polaris xplorer sputtering, polaris sportsman 500 idle adjustment, polaris xplorer sputtering, polaris xplorer sputters, scrambler 500 sputtering after getting wet, scrambler is sputtering bad, sportsman 500 sputters when wet, why does my 2001 polaris scrambler 500 backfire from the carbuerator when accelerating
