Old 07-16-2011, 12:22 PM
nyfdom's Avatar
Member #16624
Knocking noise
At idle it sounds like the engine is knocking, but then quad drives just fine... It's a 2000 scrambler 400. Anything I should be checking?
Old 07-16-2011, 12:32 PM
marc2000gt's Avatar
Member #6472
If it is just at idle, there is a good chance you are hearing the primary clutch. It will make a knocking sound when the o-rings wear out in it.
Old 07-16-2011, 12:41 PM
nyfdom's Avatar
Member #16624
Should it make a difference if it's in forward/reverse/neutral? This mean I'm likely going to need a new clutch then soon?
Old 07-19-2011, 02:55 AM
METALHOF's Avatar
Member #16584
Grab the plastic clutch cover and pull up slightly when its running at idle and see if the knock goes away. Mine does the same thing. Its the primary clutch hitting the cover. Worth a look.
05 polaris scrambler making tapping sound
2000 polaris 500 knock idle
2000 polaris scrambler 400 idling
2000 polaris scrambler 400 knocking sound
2000 polaris scrambler 400 noisy engine
2000 polaris scrambler 500 knocks when idling
2000 polaris scrambler engine noise 2000 polaris scrambler 400 engine noise
engine knocking polaris scrambler
knocking sound quad
polaris 500 engine knock at idle
polaris atv engine makes a knocking sound
polaris knocking noise
polaris scrambler 500 engine noise
polaris scrambler knock at idle
polaris scrambler knocking
polaris scrambler making a knocking noise
polaris scrambler noise in engine
polaris scrammiler 400 nocking
pololaris 400 knocking
what causes polaris scrambler 400 engine knocking sound?
2011 500 HO knocking sportsman_rider Polaris Sportsman 3 05-30-2011 12:06 PM
Knocking In Rear End mngatorhunt Polaris XP 13 05-29-2011 08:32 PM
99 sportsman 500 knocking noise ppolaris1010 ATV Repair and Maintenance 1 05-25-2011 12:38 PM
Magnum Knocking noise Brown1 Polaris Magnum 3 11-16-2010 07:40 AM
Motor knocking joeree Polaris Sportsman 9 06-03-2009 03:54 PM
