Old 07-19-2011, 01:16 PM
1fun37's Avatar
Member #16920
Scrambler 400 with no forward or reverse
I am a newbee to your forum. My buddy dropped off his 2001 Scrambler with no forward or reverse for me to fix. The shift lever moves both directions but nothing happens, no noise or movement. Am I looking at opening up the transmission?
Don't know any more history of the machine except his kids ride it hard. Thanks for any suggestions.
Fred
Old 07-19-2011, 01:33 PM
4getful2's Avatar
Member #1234
If the belt is on both pulleys,and the clutches appear to be doing their thing ,then it's probably something inside the transmission
Old 07-19-2011, 02:36 PM
1fun37's Avatar
Member #16920
4getful2,
Your advice was right on, pulled the side cover and found a mangled belt.
Old 07-22-2011, 08:55 AM
1fun37's Avatar
Member #16920
Now after cleaning out the clutch and with the new belt the secondary cluch still turns at idle making it impossible to get into forward or reverse without it killing the engine or taking off. Any suggestions? I checked with the dealer and it is the correct number for the belt.
Old 07-22-2011, 09:51 AM
tt425's Avatar
Member #3687
You might have a problem with one of the clutches. Did you install the belt so that you can read the part# from left to right while on the left side of the atv. The belts are directional. They have to be installed correctly.
Old 07-22-2011, 12:17 PM
4getful2's Avatar
Member #1234
Try cleaning the front clutch with an air hose or even a garden hose for that matter. All the years of dirt and grime ,most likely won't let the front one disengage
Old 07-22-2011, 02:38 PM
1fun37's Avatar
Member #16920
The belt was installed with the part# readible from the left side. Used 2 cans of brake clean and air pressure to clean primary clutch. I saw a Utube video on adjusting the width by shims to allow .030 clearance between the belt and clutch sheave. This one is tight and doesn't allow the belt to float on the shaft at idle. Possibly why the other belt failed.
Old 07-23-2011, 06:33 PM
4getful2's Avatar
Member #1234
The rear clutch will be hard to spread apart,normally with engine off or at idle, the top of the belt will be about level with the top of the rear clutch. At idle ,the front clutch will be spread apart and belt barely moving,if at all. Check the idle speed to make sur it's not idling to fast,600-800 rpms.
With the engine off, can you push down on the belt and make the front clutch pulley spread apart,without too much effort?
Old 07-24-2011, 03:37 PM
1fun37's Avatar
Member #16920
4getful2,
Idle is ok even, turned it down with no help, the rear clutch has the belt even with the top. I can't push down on the belt and spread the front clutch, solid with no movement. Is there something I can do to repair the clutch without help from a dealer? When you rev it does activate but doesn't return wide enought to let the belt spin free.
Old 07-24-2011, 07:10 PM
4getful2's Avatar
Member #1234
Did you look at the front clutch,as far as a broken spring,or a galled shaft,rusty parts?
2001 polaris scrambler 400 atv how fast gon in reverse
how to fix foward reverse belt on polaris atv
how to fix reverse on 01 scambler
polaris 400 scrambler history
polaris 400 scrambler transmission
polaris 400 wont go forward or reverse
polaris atv forward reverse problem
polaris atv has reverse but no forward
polaris atv has reverse but no foward
polaris atv no foward or reverse
polaris scrambler 400 belt
polaris scrambler 400 doesn't pull
polaris scrambler 400 no reverse
polaris scrambler 400 transmission
polaris scrambler no reverce
polaris scrambler no reverse
polaris sport 400 transmission
polaris sport 400 won't pull
scrambler 400 won't go into forward
scrambler without clutch
4x4 in reverse and intermittent in forward TimberGhost ATV Repair and Maintenance 6 01-26-2011 03:33 PM
either high range forward or reverse RcWheeling ATV Repair and Maintenance 4 01-06-2011 12:15 PM
Polaris 90 slipping in Forward and not Reverse? firewalker ATV Repair and Maintenance 3 01-05-2011 01:27 PM
forward feels like reverse milinstructor Polaris Sportsman 1 05-17-2010 07:02 PM
Grinding wont go forward Scrambler afranklin19 Polaris Scrambler 3 12-18-2009 01:41 PM
