08-02-2011, 11:59 AM
Member #17214
tire size?!
just bought a 500 scrambler 4x4. i'm reading that different tire sizes can cause drivetrain issues. i see that the stock rear tires are 22x11x10 and fronts are 23x7x10....i have 25x11x10 in the rear and 22x8x10 in the front. is this still ok? or do i need to replace??
1997 Scrambler 500 4x4 (work in progress)**SOLD**
2003 Trailboss 330 2x4 (wifes,not mine to touch*EDIT*MINE NOW)
2007 Toyota Tacoma Access Cab to attempt to haul it all on.
08-08-2011, 05:19 AM
Member #13457
I'm pretty new also but everything I've read says your front tire needs to be an inch taller than the rear to keep the drivetrain happy.
Scott
2004 Scrambler 500 4x4
K&N air filter
Long wish list....all in due time
08-08-2011, 06:08 AM
Member #17214
ya your right. i have since stolen my wife's tires of her trailboss which are 23s in the front and 22s in the rear. now she has the 25s on her trailboss 330..havent had a chance to ride her's yet but i'm worried if its even got enough power to trail ride now with those huge 25s
11-03-2011, 05:00 PM
Member #20152
i have 25in swamp foxes on my 400 scrambler all the way around it and it still has plenty of power. but my local mechanic told me that the one inch doesnt make any difference aslong as you only put it in 4wheel drive when youre in mud or will be spinning but when youre just driving around it will put it in a bad bind and eventually break stuff my fourwheeler is all chain drivin so i put a 1 tooth larger rear sprocket and they said that would make up the speed difference and it would be fine
2003 polaris 330 quad tire sixe, 2003 polaris scrambler 500 tire size, 2003 polaris scrambler tire size, 2003 polaris tire sizes, 2010 polaris scrambler 500 4x4 tire sizes, 22x11x10 atv tire in phoenix az, 23x7x10 on front and 25x11x10 on rear, atv in toyota tacoma access cab, atv tires 22x11x10, can i put 25x11x10 tires on a 2000 polaris scrambler 500, polaris scrambler 400 tire size, polaris scrambler 500 tire size, polaris scrambler tire size, polaris scrambler tires, tire size for polaris 2x4 scrambler, tire size polaris scrambler, what is the stock tire size on a 02 polaris scrambler, what size tire on 03 polaris scrambler, what size tire should a 1997 polaris scrambler 500 4x4, whats stock tire size on 02 scrambler
