08-02-2011, 01:42 PM
Member #13454
broke my swing arm...whoops
so like it says, i snapped my swing arm in half over the weekend. it broke in half on the left side about 3 inches back from where it bolts to the frame. i dont have like 260 bucks for a new factory part so i will be attempting to weld it back together.
does anyone know what size the bolts are on the end of the swing arm towards the front of the quad where it mounts to the frame? i dont have a socket or wrench big enough to fit it so i need to find out the size then buy the tools.
also, i havent started tearing into it yet but has anyone ever taken the swing arm out of their scrambler and have some pointers for me?
Sam
08-02-2011, 02:22 PM
OUCH!! How did you break it?!?!
Sorry I don't have any info for you...
08-02-2011, 03:15 PM
Member #13454
how did i break it? i wish i knew. i let my buddy ride it for maybe 5 minutes. he never got out of hearing distance and i could tell he wasnt beating it. he brought it back and let me other friend ride it...he took off across an open field and within 300 feet he stopped. i didnt know why. i walked up and the chain had come off. as i was putting the chain on i noticed the swing arm was broken....i really have no idea what happened.
...but it needs to be fixed. ASAP
Sam
08-03-2011, 04:15 AM
Member #3687
I don't want to be rude but if you want some help you need to post the year,2wd or 4wd,400 or 500. That will let people know what atv you have.
I can't help you either. Never worked on a scrambler.
08-03-2011, 01:01 PM
Member #13454
2000 (i think) 400 4wd
Sam
08-03-2011, 01:37 PM
Member #3687
Look on the left frame rail and you will find the VIN number. The 10th digit from left to right is the year model.
08-06-2011, 12:27 PM
Member #17315
The swingarm bolts if I'm correct are 44mm im not sure what it is in SAE but for a simpler removal take the clutches off and remove the cover connecting the engine and trans. I've replaced my output shaft before as well as swingarm so ask if you need help
08-07-2011, 07:54 PM
Member #14310
I feel your pain I cracked the swingarm on my 98 scrambler 4x4 today. It cracked on the weld right next to the bearning carrier.
08-07-2011, 07:57 PM
Member #17315
Seems to be the week spot of the swing arms... I did that once before also.
08-08-2011, 10:05 AM
Member #13454
does anyone know for sure the size of the bolt im talking about? as of now it looks like ill be buying a 44mm socket and wrench but it anyone POSITIVE what size it is?
Sam
2001 polaris 500 scrambler swingarm socket size, 2001 polaris trailboss swing arm wrench, atv swing arm breaks, can you weld a cracked dirt bike swing arm, can you weld swingarm of polaris outlaw atv, how does atv swing arm break, how to remove a swingarm on a 500 scrambler, how to remove swing arm from a polaris, how to replace swing arm bushing on 500 scrambler, is the swing arm welded to the frame on a polaris scrambler, polaris scrambler 400 rear swing arm bolts break, polaris scrambler sway arm, polaris swing arm remove, polaris swingarm removal, polaris swingarm wrench, pulling swingarm polaris trailblazer, swing arm for a 2007 polaris outlaw, swing arm removal 2007 polaris outlaw, what breaks swing arms on atv, what size socket to remove polaris scrambler swingarm
