Old 08-15-2011, 06:57 PM
bwk7088's Avatar
Member #6938
98 scrambler 500 clutch question
Hi, I hope someone can help me or send me somwhere to get the help. I have a 98 scrambler 500 and the other day I was headed back to farm and was running it wide open to get back to the farm before a storm hit. As I got it to the shop door and slowed to almost a stop The engine just died. I tried to restart it and nothing. I put it in neutral and tried and it started right up, so i then tried to put it in gear to go on into the shop but it wouldnt go into gear, it just grind...I suspected a clutch problem so took the cover off and I was right. The drive clutch was jammed in the high gear ratio by what looks like a two piece bearing like you would find in a motor (rod or main bearing). Now I know one of the best upgrades to these machines from what I've read is in the clutch (supposedly better acceleration and top end) and i have seen clutch kits but was wondering if there was a complete aftermarket performance cluth available for these scramblers. I have seen a complete clutch made by comet but am not familiar with these other than like on go karts...So are they any good and if not are there any other options? Thanks in advance...sorry so long
218875A - Comet 103 HPQ (High Performance Quad) Polaris ATV Clutch
Old 08-15-2011, 08:38 PM
Old 08-15-2011, 08:53 PM
apextrans's Avatar
Member #13457
I'm looking at a clutch upgrade also, although I don't have the problem you described. From everything I've read so far, It looks like a clutch kit from EPI is the way to go. If you go to the supporting vendors section of the forum page there is a link to their site. Pretty reasonable prices too.
Scott
2004 Scrambler 500 4x4
K&N air filter
Long wish list....all in due time
Tags
clutch, clutch kits. scrambler, comet clutch, scrambler 500
500 scrambler crankshaft bearing
98 polaris scrambler 500 clutch
98 scrambler
99 polaris scrambler clutch kit
best clutch kit for 2000 scrambler 500
best clutching for polaris scrambler 500 for mid and top performance
comet 218875a
polaris 500 clutch slipping
polaris atv clutch weight 500 scrambler
polaris scrambler 500 clutch forum
polaris scrambler 500 clutch kit
polaris scrambler 500 engine upgrades
polaris scrambler 500 performance mods
polaris scrambler clutch grinds
polaris scrambler clutch noise
polaris scrambler clutch problems
polaris scrambler clutch troubleshooting
polaris scrambler clutch upgrade
taking off a 98 scrambler 500 clutch
what size is thread on polaris scrambler clutch
99 scrambler 500 clutch question swampdonkie Polaris Scrambler 2 06-20-2011 04:51 AM
Scrambler 500 Clutch/Belt question... alankulwicki7 ATV Repair and Maintenance 4 05-17-2011 06:02 PM
Scrambler Clutch Kit Dmac Polaris Scrambler 2 11-19-2010 10:52 AM
Scrambler 500 Clutch Kit?? Lgumpp ATV Performance Modifications 3 06-23-2010 03:26 PM
scrambler secondary clutch 02scrambler Polaris Scrambler 0 04-05-2010 06:00 PM
