Old 08-17-2011, 11:25 AM
sr975j's Avatar
Member #13454
rear shock question
on the rear shock of a 00 srambler 400, can you adjust the spring to make it sit higher or lower? right now, my spring is all the way loose and with me on it, it sits really low in the rear end...can i tighten that rear spring up to make it ride a little higher?
Sam
Old 08-17-2011, 02:00 PM
rkuhnjr's Avatar
Member #5164
Tightening the spring will increase riding height as it will not compress as much but overall height it will have no effect on
Old 08-17-2011, 06:59 PM
sr975j's Avatar
Member #13454
i know that but how do i adjust it? i i did some reading and heard you can adjust it with some big channel locks....is there a better method than that?
Sam
Old 08-18-2011, 07:50 AM
rkuhnjr's Avatar
Member #5164
Assuming your shock is adjustable which it should be you will see an adjuster of some sort at the bottom or top of the spring itself that has teeth you turn that until it sits in the groove that compresses the spring the most if it looks like this one.
It may just be threaded though in which case you just tighten it like a nut until its at its desired compression.
The right tool would be a shock adjustment tool, they are fairly universal, a good spanner wrench would probably work to, channel locks and/or a pipe wrench would work too but you will mar up the adjustment nut.
Here is a pic that shows how you would do it with the proper tool
10 scrambler 500 stock rear shock
96 scrambler 400 rear suspension adjust
how do i adjust rear shock on polaris scrambler
how do you adjust a polaris scrambler rear shock
how do you soften the rear suspension on scrambler 500
how to adjust rear shock on 500 scrambler
how to adjust rear shock on polaris scrambler
how to adjust the rear shock on a polaris scrambler 500
how to raise ride height on polaris predator 500
how to stiffen rear suspension on polaris scrambler
how to tighten scrambler rear suspension
polaris scrambler rear shock spring
polaris shock adjustment tool
polaris tools shock
rear shock spanner wrench
spanner wrench polaris scrambler 400
spanner wrench shock adjustment
tool shock adjustment
using a shock wrench
will a scrambler 500 rear shock fit on a 500 predator rear? hunter51190@yahoo.com ATV Brakes & Suspension 1 10-18-2010 04:18 PM
rear shock swifty scrambler Polaris Scrambler 4 02-22-2010 01:36 PM
700 rear shock jonslink ATV General Discussion 6 02-16-2010 09:02 AM
Rear Shock Question justincsandbar Polaris Scrambler 2 01-10-2010 10:09 AM
96 rear shock djtates125 ATV Brakes & Suspension 3 01-08-2010 08:10 AM
