Old 08-23-2011, 06:17 PM
snowlover4u2005's Avatar
Member #17804
05 400 scrambler smoking using coolant
I replaced the piston, rings, clips, wrist pin, wrist pin bearing, base, and head gaskets. No help, replace the head still no help. Any ideas out there what to try next?
Old 08-23-2011, 10:44 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
i would check the waterpump seal i had one bad and was leaking antifreeze into the engine.i did everything you did but checked the waterpump seal last and that was the problem.
Old 08-24-2011, 03:11 AM
Member #17804
I am assuming it is under the water pump? Thanks for the tip. Alot cheaper than a cyclinder witch was my next step.
400 polaris smoking
antifreeze leaking into cylinder scrambler
coolant in engine polaris 400 scrambler
head gasket polaris 400 scrambler
how can antifreeze get into cylinder on polaris atv
how to change water pump on scrambler 400
how to tell if a polaris scrambler have a blown head gasket
polaris 400 cylinder fills with antifreeze
polaris 400 scambler water pump
polaris atv is using water
polaris coolant piston
polaris scrambler 400 head gasket
polaris scrambler 400 radiator fluid
polaris scrambler 400 water pump
polaris scrambler 400 why getting water in the motor
polaris scrambler 500 leaking coolent into the cylinder
polaris scrambler loosing coolant
polaris scrambler water pump seal replacement
scrambler 400 coolant
water is getting into 400l polaris motor
Polaris 50 Scrambler Smoking More robertbood ATV General Discussion 6 02-21-2011 05:27 PM
2 stroke scrambler coolant issue trxfrmwc Polaris Scrambler 4 01-26-2011 07:02 PM
Allied Electricals: Coolant Pump | Industrial coolant Pump in India Bangalore Allied Site Issues & Suggestions 1 11-19-2010 01:13 PM
Coolant Change Info 2000 Scrambler 500 4x4 Kiefer34 ATV General Discussion 2 09-23-2010 07:20 PM
Polaris 50 Scrambler Smoking robertbood ATV New Members 5 09-19-2010 09:15 PM
