08-26-2011, 09:57 AM
Member #13454
bypassing the premix
i want to bypass the premix on my 00 scrambler 400. what exactly do i need to do? jut disconnect the oil line and plug it then mix my own gas or what?
my buddy used to have the same scrambler and he said he just ran the oil tank dry then mixed his own gas and it worked fine.
so what is the proper procedure to bypass the premix?
thanks in advance
Sam
08-26-2011, 10:12 AM
Member #17395
Check this site they have a block off plate for the oil pump. So you can remove the pump and tank to save a little weight.
http://www.speedwerxstore.com/
- Sent from my iPhone using Tapatalk
08-26-2011, 10:33 AM
Member #17047
why do you want to quit using the oil pump?
08-26-2011, 12:08 PM
Member #13454
i am planning on eliminating the premix so in case the oil pump ever goes out, my motor will still be getting oil. ive heard that in the winter when its colder out that the oil can thicken causing the motor to not get the proper amount of oil it needs to run properly. id rather just mix my own gas and know that the mixture is correct.
Sam
08-26-2011, 12:48 PM
Member #17047
thats not true the oil pump and polaris blue oil is the same oil used in the snowmachines and the oil pump is made by mikuni the same company that makes oil pumps for the snowmachines.ive never seen a pump go out on the 4 wheelers or the snowmachines before.just make sure your low oil light works,and if you want to just in case you can carry extra oil and premix your gas anytime you want.you can still run both the oil injection and premix at the same time with no problem,just more smoke and you might foul a sparkplug.
09-29-2011, 05:52 PM
Member #16228
They should not go. most of the time when ppl say the pump is bad it's not...
it's the Line going to the intake leaks.
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
bypassing oil injection on polaris sport 400, how disconect oil line from 97 polaris scrambler 400, how to bypass oil pump on polaris, how to get rid of oil pump on polaris scrambler, how to remove oil injection from polaris predator 50, how to remove oil system polaris xplorer 400, oil injection block off kit 2000 scrambler 400, polaris predator 50 oil injection, polaris preditor oil pump block off plate, polaris scrambler 400 oil pump block off, polaris scrambler 50cc oil pump delete, polaris xplorer 400 oil pump delete, polaris xplorer premixing what do i have to do, polaris xplorer400 injector pump setting, predator 50 oil blockoff plate, predator 90 oil block, predator oil block off, remove oil injector on predator 50, scrambler 400 oil pump elimenate, will polaris true blue oil work for oil injection
