Old 08-29-2011, 05:27 PM
andrewd523's Avatar
Member #18096
2001 Scrambler 500 Strut/ Hub Problems HELP!!!!!!
I have a 2001 Scrambler 500 4X4. We are trying to fix the 4X4 system because it does not work at all. We took apart the right (when sitting on the quad) front hub and this is what we found. If you look at the pictures there is a chunk out of the strut. Will this be a problem if we replace the coil/ wiring? OR do I need a whole new strut?
My fear is that the gear oil will get up inside the coil/ wiring and eventually break it down. Should I be worried about this? Is there a way to repair this chunk?
Advice, help, comments... Anything would be greatly appreciated.
Thanks,
Andrew
Old 08-29-2011, 07:13 PM
Old 09-02-2011, 01:12 PM
lowgearjoe's Avatar
Member #17843
Hub problem
find you another strut! that one looks like its been to hell and back!
you can get a new one for $80. at partshark.com
Old 09-02-2011, 02:04 PM
andrewd523's Avatar
Member #18096
The part is $236 on partshark.... What were you looking at? I need the whole hubstrut, not just the outer coil.
Please let me know, if you could save me $150 I would be thrilled! I need the right one, and as of right now there are none used on ebay. I checked the part number for specific years, models etc... NOTHING
Old 09-02-2011, 06:24 PM
lowgearjoe's Avatar
Member #17843
Hub problem
Sorry about that I messed up! You were correct on your price, check around other sites! So far part shark has been more reasonable than the others!
02 polaris scrambler 500 how does the 4x4 system work
2001 polaris scrambler 500 4x4 not working
2001 polaris scrambler 500 front hub not engaging
2001 polaris scrambler 500 hub
2001 polaris trailblazer hub problem
2001 scambler hub
2001 sportsman 500 hub problem#gsc.tab
how to check year model on scrambler 500
polaris 500 hub problems
polaris atv hub problems
polaris front hub problems
polaris scrambler 4x4 not engaging
polaris scrambler hub problem
polaris sportsman 500 struts
replacement hub polaris scrambler
scrambler 500 strut gasket
scrambler 500 struts
scrambler strut
strut problem 500 scrambler
2001 500 h.o. Starting problems popo2001 Polaris Sportsman 3 03-02-2011 04:47 PM
2001 TB250 problems Tyler14 Polaris Trail Blazer 3 12-29-2010 08:42 AM
WTB: 2001 Scrambler 500 4x4 passenger side strut housing xrocket21 Polaris Scrambler 7 05-20-2010 04:30 PM
2001 Sportsman 500 Problems Help!! russellmxz Polaris Sportsman 1 03-14-2010 07:00 AM
2001 Sportsman 500 H0 key starting problems bigwavedave ATV Repair and Maintenance 2 10-18-2009 04:50 PM
