Old 08-29-2011, 06:34 PM
codynutts's Avatar
Member #18157
2000 Scrambler 500 questions
Ok.... so i just bought a used 2000 scrambler 500 4x4 and i have some problems....
1. I just put a new facotry polaris belt on this, when i ride it for awhile the belt will start to slip ( i'm not in any water or any mud, just dry grass and gravel) i can see it slipping on the primary clutch. The clutch is shinny and the weights are clean and freshly lubed. have any ideas guys???
2. my 4x4 does not work is there a motor or actuator for the 4x4 anywhere on these? I was told maybe it was the wheel sensor that was bad causing this? The atv does had a speedo gauge added on this scrambler?
Any help on this will help alot guys thanks
Old 08-29-2011, 07:14 PM
03 scrambler 500 dry weight
2000 polaris 500 scrambler 4x4 specs rims
2000 polaris 500 scrambler clutch problems or altitude
2000 polaris atv scrambler 500 problems
2000 polaris scrambler 500 4x4 specs
2000 polaris scrambler 500 clutch
2000 polaris scrambler 500 problems
2000 polaris scrambler 500 specs
2000 scrambler weight
scrambler polaris wheel sensor
2000 Xplorer400 winch w/plow questions ponchonutty ATV Repair and Maintenance 4 01-22-2012 09:38 AM
Upgrade questions on 2000 Scrambler 500 baam5774 Polaris Scrambler 1 05-03-2011 03:41 PM
2000 Sportsman 4x4 Problems/Questions emike10 Polaris Sportsman 20 01-08-2011 03:45 PM
2000 325 magnum questions topdogeye Polaris Magnum 1 10-05-2010 03:30 PM
Questions for a 2000 Mag 325 4X4 z27651 ATV Repair and Maintenance 1 11-21-2009 07:23 PM
