Old 09-11-2011, 08:19 AM
cummins666's Avatar
Member #18568
temp light on
just noticed last night that my temp light is on,,but my machine is off and strapped to the trailer..turned it over this mornin,,started right up,temp light went out..BUT,when i turn the key off..temp light comes back on..im new on here so still have to set up my sig...its a 06 scrambler 500 HO
Old 09-11-2011, 08:55 AM
cummins666's Avatar
Member #18568
any help please,,,thnx..did a search and only found temp light on when running,,not off...could this still be a sensor as well??
06 scrambler 500 H.O..stock
Old 09-11-2011, 05:20 PM
razzy2364's Avatar
Member #18587
make sure everything is full, coolant, oil, and ive had to same problem, it was the sensor
Old 09-11-2011, 06:14 PM
cummins666's Avatar
Member #18568
thnx for the input i will check into that
07 scrambler 500 fan comes on and off
2000 polaris 325 magnum fan won't shut off
2000 polaris scrambler 500 temp sensor
2000 polaris scrambler wont turn over and has antifreeze light on
how to test polaris scrambler coolant temp sensor check
how to test polaris scrambler cooling fan
oil temp light on polaris
polaris 325 fan runs lights dont work
polaris atp temp light on
polaris atv
polaris scrambler 500 temp light
polaris scrambler temp light
polaris scrambler temp light comes on but no fan
polaris scrambler temp light on
polaris sportsman temp light not working
polaris temperature light on
scrambler 500 fan
temp light on scrambler 500
testing a polaris temp light
what makes oil temp light come on a polaris sportsman 500
what is your temp? peterbilt Polaris Sportsman 11 03-22-2011 07:56 PM
2000 magnum 325 2x4 (temp light) bcarfley Polaris Magnum 6 01-27-2011 03:28 AM
2000 Magnum 325 Temp Light z27651 ATV Repair and Maintenance 7 04-04-2010 08:42 PM
Temp Light marco_wezo Polaris Outlaw 1 03-23-2010 04:14 PM
Sportsman 500 temp light comes on/fan won't auto start? Michigan Sportsman 500 Polaris Sportsman 3 03-16-2010 08:19 AM
