Old 09-19-2011, 05:34 PM
nyfdom's Avatar
Member #16624
I think my 4x4 is ruined... :(
So i haven't rode my quad in about a month, went out yesterday and got stuck a little, so i threw it in 4x4, noticed i still wasn't going anywhere then all of a sudden a tonne of smoke was coming from the seat area... Don't know what the hell happened. So i got it out and drove it in 2 wheel and didn't have any issues... I tried lifting the back end while giving it gas to see if the front wheels would go at all and they wouldn't, and it seemed like if i revved high enough i would hear a clunking (only tried this once). Im assuming my whole 4x4 assembly is done?
One other thing I noticed is that when I am trying to take off from a stop slowly (in 2 wheel), it like bucks a bit until i get going... feels like a little tug, could this be because the chain is too tight?
Btw, I have a 2000 400 4x4 Scrambler, and I do not have a light on the quad that indicates if it is in 4x4 or not, don't know why mine doesn't have it, my brothers 1996 has it.
Old 09-19-2011, 05:39 PM
tt425's Avatar
Member #3687
The 4x4 engages based off of rpm's I believe. Put it on jack stands with all 4 wheels off the ground to see if they pull.
Old 09-19-2011, 05:40 PM
Probably just smoked the belt.
Old 09-19-2011, 06:50 PM
Hawkeye 007's Avatar
Member #8077
I'll go along with blueline15.
2011 Red Touring 850
Ricochet A-Arm guards
Old 09-19-2011, 06:51 PM
jordaman17's Avatar
Member #13240
definitly sounds like a belt.
Old 09-19-2011, 08:10 PM
nyfdom's Avatar
Member #16624
So just take off the cover and on the left side?? I HOPE ITS A BELT!! (Praying)
Old 09-19-2011, 08:26 PM
800touring's Avatar
Member #14149
just the belt (for somke) and if 4x4 still is not working check the roller cage in the front diff
Old 09-20-2011, 06:22 AM
bgirard420's Avatar
Member #11494
Smoke followed by weird jerking usually means belt. Agree that you should jack it up and retest the 4WD but after you address the probable belt issue as to not muddy the waters.
2010 Sportsman 500 H.O.
Old 09-20-2011, 01:23 PM
nyfdom's Avatar
Member #16624
Ok ill have to check it out on the weekend. Anyone have a part number for the belt? Sorry, I'm new to all this, the belt should be located on the left side if sitting on the quad right? under the black plastic.
Old 09-20-2011, 01:33 PM
jshields's Avatar
Member #6457
Yep agreed smoked belt....I did this in wet grass trying to slide out the back tires...not a ton of smoke...but enough to "hour glass" the belt. It would feel like it was starting and stopping real quick and i never even tried to get it to the high rpms in fear or fubaring something else. Took it to a dealer and $170 later it rode fine.
On a furture not...if you are riding and giving it gas and the wheels are not spinning then you will possibly do the same again
polaris scrambler ruined my 4x4
