Old 09-24-2011, 09:57 AM
chefshano2007's Avatar
Member #18991
Eletrical ?
Hey all,
I'm new to the forum and have a question about my recently purchased 2000 Polaris Scrambler 500 4x4. When purchased the battery was dead, in the process of replacing, but when running using The pull start the head light, tail light, and indicator lights Arnt working. The strange thing is the break light seems to be working fine, so I no its not bad bulbs, I checked the connections quickly and they were all tight, no idea what it could be, any suggestions will be appreciated.
Thanks much guys,
Shane
Old 09-24-2011, 08:05 PM
Old 09-25-2011, 11:16 AM
redrider022002's Avatar
Member #18580
sounds like there is a blown fuse in the system somewhere. not quite sure where it is tho. ill look in my manual later today and see if i can find anything.
2000 scrambler 400 2 stroke 2wd (stock)
2006 scrambler 500 4wd (stock)
2007 scrambler 500 4wd (stock)
2012 scrambler 500 4wd (stock)
Old 11-09-2011, 06:00 PM
rideinNC's Avatar
Member #20317
i have heard from numerous people that you are not supposed to run the scrambler with no battery in it. I know that you technically can do it but people say it has been known to blow every bulb in the quad by running it with no battery. My advice is to get a battery and make sure your feeding you electrical system good voltage before trying to trouble shoot any electrical problems.
