Old 09-27-2011, 04:03 AM
97polaris500's Avatar
Member #9326
97 Polaris scrambler 500 clunking noise in 4wd
I have a 97 scrambler 500 and I wraped my winch cable around a tree then hooked
It to my jetski to move it and I had it in 4wd and started to spin the tires in reverse
And there was nasty clunking noise up front ive noticed it before it only does it when
Its under a major load. What do you think could be causing this!
Old 09-27-2011, 03:10 PM
redrider022002's Avatar
Member #18580
maybe something wrong with the overrunning clutch? did you check the driveline and axles?
2000 scrambler 400 2 stroke 2wd (stock)
2006 scrambler 500 4wd (stock)
2007 scrambler 500 4wd (stock)
2012 scrambler 500 4wd (stock)
Old 09-28-2011, 07:27 AM
Member #9326
Whats is overruning your clutch! & i havent checked anything yet i just want to see if anyone has had the same issue!
Old 09-28-2011, 08:21 AM
Member #18580
it's inside the front axle housing. it's what activates the 4wd after a 20% slip in the rear wheels. I would check the u joints in the driveline and the axles really well first tho
Old 09-30-2011, 07:22 AM
Member #9326
Thanks i will check that out later and let you guys know
2007 polaris scrambler clunking sound
4wd atv makes a clicking noise
97 polaris atv 500 clutch kit
97 scrambler atv
atv clunks in 4wd
clunk sound in driveline of quad
clunking noise in 4wd scrambler 400
my polaris makes clunking sound from rear
polaris scrambler 4wd test
polaris scrambler 500 clutch kit
polaris scrambler 500 noise
polaris scrambler clunking noise
polaris scrambler clunking noise when backing up
why does my polaris atv make a noise in 4wd
clunking noise 2011 polaris 500 ho wowtah21 ATV Repair and Maintenance 2 06-04-2011 04:50 PM
Clunking noise when going down hill paul van treeck Polaris Sportsman 2 11-15-2010 06:25 AM
06 scrambler noise -- could be nothing? zeer Polaris Scrambler 2 01-31-2010 04:20 PM
Clunking Noise ItODDospeed ATV Repair and Maintenance 4 10-06-2009 03:49 AM
01 400 scrambler Noise ddotmueller ATV Repair and Maintenance 1 09-24-2009 06:28 PM
