09-29-2011, 04:28 AM
Member #19119
Outer Tie Rod Ends
I'm in need to replace my outer tie rod ends and notice a few sites stated "if built before 8/16/99 use this one, built after 8/16/99 use this. What was the change and how can I decode the VIN to know what I have? Is there a visual differances?
Should I take the chance to order the cheapest or just go for OEM
09-29-2011, 05:29 AM
Member #13981
9&10 digit
RickH,Mike here.Welcome to the forum.If you will count the digits in your vin.# according to Polaris the 9th digit is the (month) and the 10th digit is the (year).Hope this helps,  Mike
09-29-2011, 06:13 AM
09-29-2011, 08:13 AM
Member #18006
Rick H; Just a quick note that may save you a ton of $$$. I replaced tie rod ends on my wife's 07 700 after I bought it. Was disgusted by how much they cost. Now have rebuilt the front end entirely with the help of some used parts and e-bay parts. Found a great parts reseller if you are interested. I bought 2 complete tie rods, with all 4 ends from an 06 700 for only $20. The parts are great. I also picked up a whole front CV shaft that was in better shape than the one I was trying to rebuild. $80 rather than $400 for New OEM. I am quite happy with the reseller. If you want, go to e-bay, advance search, and search by seller for the seller "rivergrange_powersports". If you go to his store you can look at available parts by manufacturer and model. I have bought multiple parts here and have not been disappointed. Hope it helps
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
10-02-2011, 05:41 PM
Member #19119
That guy has a whole lot of parts.
Thanks!
10-03-2011, 04:03 PM
Member #18006
Thanks!
Hope he had some that help you. He has been good to me and so i am happy to send more business his way so he can help you too.
10-24-2011, 02:31 PM
Member #19823
doesnt really matter i had the old style on my scrambler and just switched it over this weekend to the new style with no problems got a kit from quadboss.com came with inner and outer tie rod ends for both sides cost about 60.00
1995 polaris 400 sportsman outer tie rod end, both side sportsman tie rod ends, how to know when to replace tie rods on a polaris sportsman, how to replace tie rod ends on a quad, how to tell if my tie rod ends are bad 06 700 polaris sportsman, outer tie rod end polaris sportsman, poalris scrambler tie rod, polaris atv tie rod end substitute, polaris atv tie rod ends, polaris sacrambler tie rod, polaris scrambler tie rod end, polaris scramblern tie rod end, polaris sportsman 700 tie rod end mod, polaris tie rods bad, powered by vbulletin outer bay, replacing tie rod ends polaris sportsman, sportsman 700 tie rod, tie rod ends for 99 polaris scrambler, tie rods for sportsman 700, universal tie-rod ends for polaris atv
