Old 10-03-2011, 07:00 PM
DevonD's Avatar
Member #19140
Clicking in transmission?
So the 99 500 I bought is making a clicking noise in the transmission. It doesn’t make the noise when it’s stopped but as you start to roll it begins clicking. It doesn’t have any rhythm and it’s not consistent but just randomly it will click. I have read some others had a similar problem where it would make a clicking in the transmission when it was stopped and it was the pre clutch so I’m guessing it’s something to do with the clutch but I’m wondering how difficult it will be to fix? The noise stops as you start to speed and doesn’t start again till you slow down. The noise happens the most when its going slow, almost at a crawl.
Anything you guys can think of would be greatly appreciated! I’m brand new to these things.
Old 10-03-2011, 07:18 PM
Gear_Head's Avatar
Member #14439
with the machine in neutral, does revving it make it do it? Does it sound like it is coming directly from the transmission, or the transmission clutch side area?
Old 10-03-2011, 07:35 PM
DevonD's Avatar
Member #19140
It only does it in drive. when you rev it in neutral it makes no noise. It almost sounds like something hitting the plastic from the inside of the transmission cover
Old 10-04-2011, 05:46 AM
Gear_Head's Avatar
Member #14439
The plastic clutch cover? If so, sounds like it is time for you to get familiar with it by removing it to see what is going on inside.
Old 10-04-2011, 03:48 PM
DevonD's Avatar
Member #19140
I took the cover off and the drive clutch is rattling around and hitting the plastic cover. My guess is that some bearings somehwere are shot and need to be replaced. I dont think its the crank shaft bearings because it doesnt do it when the quad is in Neutral. It only does it when a load is on it, like the drive belt tightening and pulling. I'm hoping its as easy as a clutch rebuild. Does anyone know of a good rebuild kit I could buy? and what is a good belt for these things? maybe its just because the clutch needs to be rebuilt but i think it could be slipping too. Thanks again!
can am atv clutch clicking noise
clicking from transmission
clicking in transmission
clicking sound from transmission
clicking transmission
polaris atv popping in the transmission
polaris makes a noise when it is in neutral
polaris scrambler 500 clicking from transmission
polaris scrambler 500 clicking from transmission in neutral
polaris scrambler clicking noise
polaris scrambler gearbox popping
polaris scrambler popping into neutral
polaris trans rattle
polaris transmission popping noise
pop sound neutral atv
rebuild polaris scrambler transmission
scrambler 500 clicking noise
ticking noise inside tranny when in neutral
what can make a clicking sound around transmission
why does my atv have a ticking noise when i roll it
Clicking in Transmission criso ATV Repair and Maintenance 0 04-17-2011 02:20 PM
Starter clicking Makavel07 ATV Repair and Maintenance 13 04-01-2011 03:05 PM
00 magnum 2X4 transmission clicking in neutral sassah ATV Repair and Maintenance 0 01-31-2011 04:33 PM
2010 850 xp adc clicking Rubicon276 ATV Repair and Maintenance 4 10-26-2010 04:57 AM
clicking sound bird barrel ATV Repair and Maintenance 2 10-08-2010 10:18 AM
