Old 10-05-2011, 08:57 PM
bigg4wheeler's Avatar
Member #19334
Scrambler 500 4x4 tire questions
I have a 2001 Scrambler 500 4x4. I'm looking at putting a set of 12" STI C7 wheels on it and a set of mud tires. My question is, can I put a set of 25" tires front and back or do I have to have something like 26" on front and 25" on back? If I do 25s all away around will it mess up the final gear ratio? Thanks
Old 10-06-2011, 04:36 PM
redrider022002's Avatar
Member #18580
if you put the same size tires on both front and back it will screw with the ratio in your 4wd. stock it is set up
for a 20% difference in wheel speed from back to front. that means the back tires have to slip 20%, or 1/5 of a rotation for the front tires to start receiving power.
2000 scrambler 400 2 stroke 2wd (stock)
2006 scrambler 500 4wd (stock)
2007 scrambler 500 4wd (stock)
2012 scrambler 500 4wd (stock)
Old 10-06-2011, 05:20 PM
Old 10-06-2011, 07:31 PM
Member #19334
Alright, thats what I was thinking. Another question, I'm going to install a EPI clutch kit setup for 27"/28" tires. I'm looking at a set of Zilla tires, sizes 26" front and 25" back. The front has a tread thickness of 1.2" and the back is .75". Would this setup work?
Old 10-06-2011, 08:14 PM
Member #18580
sounds like it will work just fine. I've heard good things about epi.
Old 10-06-2011, 08:23 PM
Member #19334
Thanks for the info, just dont want to overload the wheeler.
Tags
scrambler 500
08 scrambler polaris tire upgrade
2001 polaris scrambler 500 4x4 wheels
are polaris scrambler 400 and 500 tires the same?
best polaris scrambler set up
best tire for polaris scrambler
biggest tires that you can put on a 2001 polaris scramler 500 4x4
blogs same sizes tires on polaris scrambler 500
can i run 26 tires on polaris scrambler
clutch setup on a 500 scrambler with 28 tires
mud tires on polaris scramblers
polaris scrambler 400 500 front wheels same size
polaris scrambler 500 4x4 max tire size
polaris scrambler 500 4x4 stock tire size?
polaris scrambler 500 with 25' wheels tires
polaris scrambler tire size
polaris scramblers tire size
scrambler set up size
stock tire size polaris scrambler
what is the biggest tire you can put on a polaris scrambler 500
what is the rear tire size on a polaris scrambler 500
97 scrambler trans questions! 97polaris500 Polaris Scrambler 0 05-13-2011 11:20 AM
scrambler questions chevyman98 Polaris Scrambler 5 04-07-2011 01:54 PM
Tire size & wheel questions & thoughts. scottdeet ATV Wheels & Tires 9 03-11-2011 12:58 PM
Many Scrambler questions djr8505 ATV Repair and Maintenance 6 06-23-2010 06:08 PM
A couple of tire questions pertaining to Mudlite XL's and sizes jethrob ATV Wheels & Tires 2 04-25-2010 07:12 PM
