Old 10-23-2011, 04:38 PM
97polaris500's Avatar
Member #9326
97 scrambler chain and sprockets
ive got a 97 scrambler 500 with a low range trans swaped in and 28" mudzillas all around!being that the front tires are sapose to be 1 inch short then the rear having the same size tires is going to bind up my drive line and it has i blow my stock trans so i swaped that out and i went out this weekend everything was fine until the end of the day and i was going through a mud pit and my chain pop off. long story short i got it back to the house and i noticed that my rear sprocket is rear wore and my chain was really loose once i put it back on and my front is worn and missing some teeth! so i figure its time to change my sprocket i know in the 95 sportsman 400 4x4 had the same size tires stock and back then were setup just like my scrambler so im going to swap the sportsmans sprockets onto my scrambler!
now my question is has anyone ever done a sprocket swap for the same size tires?
and what involved in changing the chains and sprockets?
Old 10-26-2011, 07:05 AM
Member #9326
Anyone
Old 11-02-2011, 10:18 AM
Member #9326
Wow no one can help me with a sprocket change! I thought someone on here would have done that already
2010 500 scrambler sprocket
95 sportsman 400 stock sprocket size?
97 polaris scrambler rear sprocket
changing a sprocket on a polaris scrambler
changing sprockets on a polaris scrambler
how to change a sprocket on a polaris scrambler
how to change a sprocket on a scrambler 500
how to tighten a polaris scrambler atv chain
how to tighten chain on polaris scrambler
how to tighten front chain 97 scrambler
polaris scrambler 400 drive sprocket loose
polaris scrambler 400 front sproket
polaris scrambler 500 drive sprocket
polaris scrambler chain and sprocets
polaris scrambler chain and sprocket specs
replacing sprocket 97 polaris scrambler
scrambler polaris sprocket
what chain for a scrambler
what size sprockets for my 95 sportsman
Chain adjustment on 99 scrambler 400 4x4 jhoite ATV New Members 3 10-24-2011 08:25 AM
1999 Trail Blazer Chain & Sprockets sledsrus1 ATV Repair and Maintenance 3 12-25-2010 08:51 AM
sprockets and chain 07Scrambler Polaris Scrambler 1 06-21-2010 04:41 AM
Ordered a bunch of stuff!! Tires, chain, sprockets, etc redneck2725 ATV General Discussion 0 05-20-2010 04:29 PM
Need opinion on chain/sprockets galaxiedan Polaris Predator 3 10-02-2009 05:24 PM
