Old 11-16-2011, 04:00 PM
812monster812's Avatar
Member #20502
Scrambler Widening
Hi everyone. I ride an 04 500 4x4 scrambler and am looking to widen the stance a bit. Wheel spacers have given me problems in the past with other quads so I wanna stay away from them. Im looking to get a set of offset aluminum wheels. Can any of you help with any suggestions of brand, style, and or offset numbers? More importantly where to buy them? And a front rim that will work with the protruding hubs. Im looking to gain around 2-3 inches total front and rear. I want to keep the factory tire size and just want a plain black aluminum rim, nothing fancy. Any advice would be appreciated!
2004 Polaris Scrambler 500 HO 4x4
2005 Kawasaki KFX400
Old 11-20-2011, 06:41 PM
poposcrammy's Avatar
Member #20152
goto vision wheels there wheels may be fancier than wat u want though
1996 POLARIS SCRAMBLER 400
.025 ovebore wiseco
fmf grnarly head pipe stock silencer
25in swamp foxes
12 vision buckshot wheels
purple polaris sport seat to match shocks
v force carbon fiber reeds
reed spacer kit
uni airfilter
COMING SOON
Purple polaris sport hood
aftermarket silencer from hpd-inc.com
cluctch kit also from them
Old 11-21-2011, 02:42 PM
Member #20502
I looked at Vision Wheels but all I could find were 12 or 14 inch wheels. I would like to keep the factory size tires and rims just want to replace the stock steel with aluminum. I guess I was being a bit picky in the original post. Ive had scramblers in the past but always used the stockers, I didnt realize they had the old bolt pattern. Allow me to be a little less picky and just ask: What aluminum rims are available for the scrambler in the factory size? Ill worry about the offset later. I simply cant find an aftermaket aluminum rim that will fit the rear 4/4 bolt pattern.
Old 11-21-2011, 03:12 PM
Scrambler 400 4x4's Avatar
Member #12184
look on denniskirk.com thats where i got mine
Old 11-23-2011, 02:00 PM
Member #20152
douglas makes aluminum wheels like that but theyre a lil fragile for hard trailing
.025 ovebore wiseco
25in swamp foxes
reed spacer kit
uni airfilter
COMING SOON
Old 11-23-2011, 04:25 PM
19psi's Avatar
Member #17818
I have some ITPs on mine.
02 Polaris Scrambler 400 4x4 ITP Wheels, ITP mudlites, Fox rear shock, winch
02 Kawasaki Prairie 650, Kenda Executioners
07 Chevy Duramax 4x4 tow rig, Banks tuner, turbo back exhaust, 18" rockstars, HIDs, LEDs, and more.
12 rims for polaris scrambler atv
1996 polaris sportsman 400 wheel offset front
2005 polaris scambler wheele off set
2005 polaris scrambler 500. ho rear tire size
2005 polaris scrambler rims
aluminum rims to fit polaris scrambler 500
bolt pattern on a 2004 polaris scrambler
how much is it to widen a 2004 polaris scrambler 500
hpd-inc.com
polaris scramble rfront wheel spacers
polaris scrambler 500 tire size
polaris scrambler rear bolt pattern
polaris scrambler tire size
polaris widening
scrambler 400 rear bolt pattern
scrambler 500 offset
scrambler widen front
stock offset polaris 500 wheels aluminum
where to buy polaris scrambler rims
widening a polaris scrambler
