Old 12-03-2011, 06:34 PM
michaelbell85's Avatar
Member #5587
Cant get scrambler to idle properly
I start my quad and it starts just fine. then when i rev it come down but goes into a high idle. Tried adjusting idle screw and air fuel and does the same thing everyntime. Really hoping its not crank seals.Think it could be a gasket to intake or manifold rubber. Any help or suggestions would be nice.
Old 12-03-2011, 07:16 PM
buddy_1's Avatar
Member #15674
Year model? 400 or 500? Any recent repairs?
1999 Sport 400 2x4
Complete rebuild w/Wiseco piston by Todd Kerby
Comet clutch
Swamplites front & rear
03 Predator Rear Hubs
ITP Pro Baja Wheels (4x156 front & rear)
DG Front Bumper
Fuj Rear Grab Bars
Old 12-04-2011, 10:03 AM
Member #5587
no recent repairs 1999 scrambler 400
Old 12-04-2011, 10:31 AM
4getful2's Avatar
Member #1234
Could check the carb. slide, it may have a worn spot that is not allowing it to fall down where you want it too. may also check throttle cable,for slack or bad spots
Old 12-04-2011, 11:12 AM
buddy_1's Avatar
Member #15674
Also, check rubber intake boot for cracks, tears or splits. Could be sucking air causing it to lean out.
1999 Sport 400 2x4
Comet clutch
DG Front Bumper
Fuj Rear Grab Bars
2001polaris scrambler atv idle screw
400 scrambler revving really high
adjust idle speed polaris outlaw 90
adjustment screw polaris outlaw 90
how to adjust idle on polaris 50
how to adjust idle on polaris 500 scrambler
how to adjust idle polarid 90
how to adjust idle speed on polaris scrambler
how to check crank seals 90 scrambler
idle adjust on 2001 polaris scrambler
idle adjustment scrambler
polaris 500 scrambler not idleing
polaris 90 idle adjustment
polaris atv 90 throttle adjustment
polaris scrambler 400 adjust throttle
polaris scrambler 400 forum idle
polaris scrambler throttle adjust
scrambler 400 throttle adjust
what is the air screw setting for a 2001 polaris scrambler 90
where's the idle adjustment screw on a scrambler 400?
2008 Outlaw 90 starter not engaging properly stevensj13 Polaris Outlaw 1 09-12-2011 07:45 PM
How to properly check the oil on a 06 450 Sportsman ChaoticDave Polaris Sportsman 4 04-29-2011 06:49 AM
02 scrambler 50 hard starting and will just idle doorider ATV Repair and Maintenance 0 04-08-2011 05:19 PM
how to properly preload and set 2-2 on secondary spring 425whpsti Polaris Scrambler 10 01-09-2011 04:24 PM
2002 sportsman 500 wont start properly redflaresidez71 ATV New Members 4 12-30-2010 06:03 PM
