12-18-2011, 02:32 PM
Member #21160
2001 Scrambler 500 4x4 front hub ?
Hey guys,
I had a little issue with my 2001 Scrambler 500 4x4. I installed a new CV boot the other day. Everything went fine. I looked up the torque specs for the axle nut. My haynes manual called for 100 lb. I didnt think that was right. I torqued it to 100 lbs and it wouldnt turn at all, that much torque had it locked down. So, I backed it off until it felt right, fairly snug, with no wobble or play in it. I got it all put back together and when I test drove it, it was pulling hard to the right, like one wheel was in 4wd. It had me puzzled, I drove around, did a few dough nuts and it felt like it released, it wasnt pulling to one side any more. Is it possible that the front wheel was in 4wd and it released on it own after driving it a little. I also drained and added the Polaris reccommended hub fluid to both sides. So, it has the proper amount and type of hub fluid in it.... Anybody ever heard of this or know anything about it, this is my 1st polaris product..
THANKS
12-18-2011, 03:58 PM
Member #18654
i have heard of this happening, people have said to reverse for a bit to fix this. Changing fluid is a good way to go
12-18-2011, 06:19 PM
Member #21160
Yeah,
it probably unlocks like some automobile 4x4 systems.....I know some vehicles dont unlock until u drive in reverse a little bit.
I changed all the fluids just recently, mainly cause I just bought it used and I didnt know how old all the fluids were or if they had water in them. I usually do that when buying something used.
thanks 4 the reply
12-23-2011, 07:34 PM
Member #16364
Originally Posted by SCBASPEC2000
Yeah,
thanks 4 the reply
The manual says to go to 140in lbs while turning the hub, to seat the bearings, then back off to the closest opening for the castle nut. My 500 does that too sometimes when i service the hubs. I always putt around on it for a little bit after doing any kind of service on my quad.
This also may help
ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
12-30-2011, 04:29 PM
Member #17818
mine does it also. after a few feet of riding, it's releases. i'm sure it's just the design of the hubs, nothing to worry about.
02 Polaris Scrambler 400 4x4 ITP Wheels, ITP mudlites, Fox rear shock, winch
02 Kawasaki Prairie 650, Kenda Executioners
07 Chevy Duramax 4x4 tow rig, Banks tuner, turbo back exhaust, 18" rockstars, HIDs, LEDs, and more.
03-15-2012, 08:58 PM
Member #23482
If you overtighten the hub nut it will cause the front end to stay in 4x4 all the time. Most people do not have a torque wrench so the best way I was told by a Polaris mechanic is to hand tighten the nut, spin the wheel a few times, hand tighten the nut again, spin the wheel a few more times, hand tighten the nut once again and back off to the nearest cotter pin hole. Keep in mind, if you run your quad in 4x4 more than it should or have the back tires spinning faster than the front tires engaging the AWD in and out this will magnetize the armature plates causing the front end to stay in 4x4
03-20-2012, 08:21 AM
Member #5132
You torqued the nut to 100 ft-lb. That is 12 times more than the correct troque of 100 in-lb. Mind the units.
03 scrambler hub nut torque, 2001 polaris scrambler 500 4x4 specs, 2001 scrambler 4x4 wont work, how much fluid in front hubs on scrambler 500, polaris atv front hub nut size, polaris scrambler 4 x 4 front wheel lock, polaris scrambler 500 4x4 hub level, polaris scrambler 500 4x4 not turning on, polaris scrambler 500 4x4 pulls right, polaris scrambler 500 front hub rebuild, polaris scrambler front hubs torque, polaris scrambler hub lube, polaris scrambler hub torque, polaris scrambler locked front hub, polaris scrambler what type fluid do i put in front hubs, what fluids are needed in a 01 polaris scrambler 500 4x4, what is the fluid in the hub of my 2001 polaris scrambler, what to tight polaris scrambler front axle nuts, what torque put on nut on front wheel of 4x4 hub on 2002 polaris 400?, what type of fluid goes in the hub of a polaris scrambler
