Old 12-27-2011, 01:09 PM
adamcr80123's Avatar
Member #18654
Polaris scrambler awd
Hey everybody, is there a way to make the scrambler an awd? I have a 400 4x4 and would love to make it awd with the 4x4 fully engaged all the time. If anybody knows how to do this let me know. Thanks
Old 12-27-2011, 01:28 PM
Member #18654
Ya the 4x4 only engages when the rear tires are spinning. I would like to have the switch engage 4x4
Old 12-27-2011, 03:18 PM
I do not recommend doing this. The system is not built to handle being locked in (you'll be replacing steering and gearcase parts often), it'll be like trying to steer an army tank with handlebars, you will hardly be able to turn.
I don't know why you would want to take a system that polaris spent huge money, and years refining and patenting and remove it. You'd be better off having a yamaha with the limited slip front in. Then you could lock in the gearcase after you come to a complete stop. It still wont steer worth beans at that point.
Regardless, put tires that are either 20% larger diameter on the rears only, or 20% smaller diameter on the fronts only, and it'll stay locked in. Or, you can change the sprockets so you gear the machine so the rear axle is spinning 20% faster then the stock gearing. That will also lock it in.
Again, these are very bad ideas, I do not recommend it in any way. You will grenade the front end and quickly turn this machine into a 2x4 only.
Old 12-27-2011, 04:15 PM
4getful2's Avatar
Member #1234
While this does sound like a good idea,it's not entirely possible, due to the way way the hilliard clutches are designed in the front hubs.
I agree with blueline,it would be a bear to steer, the front differential on your unit and all other polaris's is a spool type( read POSI) ,and does not allow for turning.
Old 12-27-2011, 10:56 PM
scramblinman 01's Avatar
Member #14428
I agree,steering would be horrible locked in. When the 4x4 system is working Correctly it's hard to tell it's not locked in,besides it's easy to steer. I've been snow plowing,mudding,and everything else besides rock crawling since late 2000 and the system works Great for me.
are all polaris scramblers 4wd
awd stuck on polaris scrambler
cost of fixing awd scrambler 400
four wheel drive scrambler400-troubleshooting
four wheel drive scrambler400-troubleshooting#gsc.tab
how to change sprockets on a scrambler 400 4x4#gsc.tab
polaris 500 scrambler 4wd engagement
polaris scmabler 400 all wheel drive switch
polaris scrambler 400 all wheel drive switch
polaris scrambler 400 awd
polaris scrambler 400 awd problems
polaris scrambler 400 does not go into complete 4x4
polaris scrambler all time 4x4
polaris scrambler awd fix
polaris scrambler awd switch
polaris scrambler awd switch broke
polaris scrambler awd switch#gsc.tab
polaris scrambler rick ritter
scrambler awd stuck
when did polaris offer awd on scrambler 400?
Polaris 400 scrambler HELP!!!! ShadetreeSam ATV Repair and Maintenance 10 08-17-2011 06:04 PM
Polaris scrambler Help!!!!!! scramblerking Polaris Scrambler 2 12-05-2010 07:53 PM
Polaris scrambler Help!!!!!! scramblerking Polaris Scrambler 8 12-03-2010 04:17 AM
polaris scrambler 500 no 4x4 weightset ATV Repair and Maintenance 1 02-25-2010 06:12 PM
polaris scrambler 4oo cdi fit on polaris trailblazer 250? trailblazerpr ATV Racing Discussion 2 06-12-2009 07:30 AM
