Picked up a used sportsman front end for $40 on ebay, I've seen a ton of these go for for that cheap, so If anyone else wants to try it, It's pretty easy. I relocated the stock bumper lights to the inside of the frame instead of outside. I trimmed the rack support to fit the scrambler plastics. 2 simple cuts was all it took. I'm going to install a winch plate, but I was test fitting in the pictures below.
The scrambler & the sportsman have the same mounting points on the frame, so this is pretty much a bolt on upgrade.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
