Originally Posted by sharvit9
hello
i have scrambler 4x4 2005
the right front wheal alweys engeged and spining
i replace beetwin the hilihard clutch system and the problem is steel appier
anybody fix it befor ? or anybody know whats this
thanks
sorry about my english
I would check the wires running to the hub. easy way to check is to unplug the connector to that wheel / hub. Just to be sure you do not have power continuously running to that wheel when you have 4x4 turned off. And make sure you have the proper amount of oil in the hubs.
next culprit is usually the armature plate, this plate can be permanently magnetized over time once it is wore down. I always replace this if I'm opening up the front 4x4 system. very cheap part to replace.
Only thing left is the Hilliard clutch itself. It's possible that the rollers are sticking. you can check this by moving the rollers around and feel for bind spots. The spring that runs around the clutch / rollers is also super sensitive. If you removed this spring during your repair, there is a chance that is has been stretched beyond use.
One more thing...
You also need to be sure to have the axle nut set to the right torque specs.
